  3. when I created via,this window appeared
  • Views 1173
LEOMESSI
LEOMESSI over 3 years ago
The pdk is FREEPDK15
how to deal with this situation?
THANKS!
    Probably best not to use FreePDK15. It's pretty basic and doesn't include many features required for any decent PDK. I see there are a bunch of layouts in the NCSU_TechLib_FreePDK15 library that appear to be fixed layouts for various vias, but none of these are referenced in the technology database for the library - so there are no standard vias nor custom vias defined in the tech file. There are hardly any technology rules / constraints defined in the tech file either.
    You can either contact NCSU (since it's their PDK), or maybe you'd be better off using one of the generic PDKs from http://pdk.cadence.com instead?
