  3. Creating layout window when clicked on the custom menu in...
  • Replies 8
  • Views 9533
Creating layout window when clicked on the custom menu in schematic
SureshT
SureshT over 3 years ago
Hello all,
I want to create a new layout window when in clicked on the menu that i have created and inserted in schematic window, Please help me to do this.
I have searched on creating a layout window but i am not finding any thread on this. I am using Cadence Virtuoso Version IC6.1.7 currently.
Thank you.
    Use the geOpen() function with ?lib, ?cell, ?view and ?mode arguments specified. Probably ?viewType "maskLayout" too (depends on whether the layout view exists already or not as to whether that's required or optional).
  • SureshT
    Thank you so much for reply
    When I use geOpen() function it will only open when it is exists before I want to create when i don't have layout view created before.
    geOpen( ?window hiGetCurrentWindow( ) ?lib "mylib"
    ?cell "mycell" ?view "layout" ?viewType "maskLayout" ?mode "a" )
    Thank you.
    Andrew Beckett over 3 years ago in reply to SureshT
    You could use ?mode "w" for that. Or use dbOpenCellVewByType() in mode "a" before calling the geOpen in mode a - for example:
    let((cv)
      cv=dbOpenCellViewByType("mylib" "mycell" "layout" "maskLayout" "a")
      dbClose(cv)
  • SureshT
    let((cv)
      dbClose(cv)
    The schematic my cell is getting open open repeatedly. And layout view is not getting created.
    And geOpen() function i have 'a  'r mode to open cellview for edit and read respectively
    Thank You
    I can't see any reason why opening a new layout window this way would open a schematic repeatedly (there's a possibility that if it was an existing layout view set to open in VLS XL, it might open the corresponding schematic, but it's not clear that's the case here).
    Without seeing your actual code, guessing what you're doing is nigh on impossible.
  • SureshT
    The code is same as you have share before
    let((cv)
      cv=dbOpenCellViewByType("SKILL_PROGRAMMING_PRACTICE"  "Inverter" "layout" "maskLayout" "a")
      geOpen( ?window hiGetCurrentWindow( ) ?lib "SKILL_PROGRAMMING_PRACTICE"
        ?cell "Inverter" ?view "layout" ?viewType "maskLayout" ?mode "a" )
      dbClose(cv)
    Thank you.
  • SureshT
    SureshT over 3 years ago in reply to SureshT
    I am not getting why the schematic window is getting open continuously. Please help  me out.
    Thank you.
    If that's the only code you have, then it really can't possibly cause the schematic window to be continuously opened (I'm not really sure what you mean by that; I can image there's a case where a single schematic window is open if the layout is set to open in Virtuoso Layout Suite XL, but it shouldn't open more than one schematic). Is the layout opening in VLS XL? After all, the code is only opening a single layout window...
    My guess is that you have some other code which is causing a schematic to be opened, but without more details it's not really possible to help.
    It would probably make more sense to contact customer support (submit a case after logging in) so that one of the application engineering team can take a look at this together with you.
