  3. Run transient with cmin option but applied to certain sub...
  • Subscribers 136
  • Views 10660
Run transient with cmin option but applied to certain sub-circuits only?
StephanWeber
StephanWeber over 3 years ago
I run schematic simulations, and see a dirty behavior if I use cmin=10f. So some nets are very sensitive to parasitic caps. Although the circuit is no high-speed circuit at all (so 10fF should not cause a problem).
However, as the circuit is large, it is hard to find the critical nets. One thing that may help is to have cmin only for certain blocks, is this possible?
Bye Stephan
    Andrew Beckett over 3 years ago +1
    Stephan, You can do this via the MTS interface these days - assuming that you're using a config for your test, go over the test name in Assembler, and Right Mouse→MTS Options. You'll see there that you…
    ShawnLogan over 3 years ago
    Dear StephanWeber,
    I do not know of a means within the Cadence framework to select the portions of a netlist where a convergence capacitance of value cmin should be added to each net. However, a possible workaround is to write a simple script to add a capacitance value of -cmin at each node of those subcircuits you do not wish to have an added capacitance of cmin added. In this fashion, the value of cmin will be added to all circuit nodes, but for those nodes you added the new nodal capacitance of -cmin, the net added capacitance wll be zero.
    Shawn
    Stephan,
    You can do this via the MTS interface these days - assuming that you're using a config for your test, go over the test name in Assembler, and Right Mouse→MTS Options. You'll see there that you can set cmin on specific cells or specific instances. That's the cleanest way in ADE, but it's also possible as a option statement (can be done via the additional arguments on the Simulation→Options→Analog form too (on the Miscellaneous tab) - see How to add cmin to specific instances or subcircuits during Spectre simulation?
    Andrew Beckett over 3 years ago in reply to Andrew Beckett
    I should also point out that cmin should really be a last resort - it normally suggests a problem with your device models.
  • StephanWeber
    StephanWeber over 3 years ago in reply to Andrew Beckett
    Thanks for these hints! In my case the design was really very sensitive to parasitic caps, so post-layout simulation was giving unfortunately also a significant performance change. No problems on device models so far.
    Bye Stephan
