  3. Could not find netlist procedure: _spectreCap instance
  • Views 3688
CJYEHRAYRAY
CJYEHRAYRAY over 3 years ago
Hi there,
Thanks in advance for your kindly reply.
While I have a spectre simulaiton, which include the "cap" instance form analoglib in my schematic.
It shows the error message below
However, everything is fine in the instanace such as ind, res...
Have you also met that situation?
Sincerely
Ray
    Ray,
    I didn’t do any searches or checks related to this specific error, but I’d say the most likely explanation is that your cds.lib is pointing at an analogLib from a different installation than the IC version you’re using. If that happens, the CDF may be requiring netlist procedures not defined in the version you’re using.
    Can you check that?
  • CJYEHRAYRAY
    CJYEHRAYRAY over 3 years ago in reply to Andrew Beckett
    Hi Andrew
    Thanks for your prompt and kindly reply.
    I delete some panic log file and cdslck file and somehow, it can start simulation without above error.
    Thanks you
    Sincerely
    Ray
    Andrew Beckett over 3 years ago in reply to CJYEHRAYRAY
    Neither of these can have anything to do with a netlist procedure not being found. Presumably something else changed in your environment, but it wasn't deleting of a panic log file (nothing would care about that) nor would clslck files cause this.
