  3. Help on creating layout for a symmetric circuit by stitching...
  • Views 2993
Help on creating layout for a symmetric circuit by stitching two "half-layout"
A1vis
A1vis over 3 years ago
Hi all.
Recently I was given a symmetric circuit and told to create a layout for it. Under my tutor's instruction, I removed half of the instances and created a half-circuit, from which I created a layout. Then in a new layout I imported the half-layout, mirrored it and stitched them together.
After some routing it could pass DRC and LVS check so I knew it's correct, but in the process of routing I found it annoying that all nets and (sub-)cells did not have any name, and I had to resort to my memory.
Following some instructions online I set both layout to transparent to establish device correspondence, but there weren't any change in the layout. New routing in the top level got their inferred name - but they were all wrong.
I'd like to ask what is the best practice of creating layout that takes the advantage of symmetry? Or maybe I should manually place the cells symmetrically?
  • RobMan
    RobMan over 3 years ago
    You can consider the following..
     Cloning
    What Is Cloning? (Video) (cadence.com)
    Invoking and Using the Generate Clones Form (Video) (cadence.com)
    support.cadence.com/COSAgreementPage?artId=a1Od00000066MKhEAM&caseSessionKey=null&id=069d0000003Etg0AAC&sq=null
    Virtuoso Layout Suite XL: Connectivity Driven Editing User Guide -- Instance Cloning (cadence.com)
    Transparent instances
    support.cadence.com/COSAgreementPage?artId=a1O3w000009flfIEAQ&caseSessionKey=null&id=0693w00000DbxQGAAZ&sq=null
    Virtuoso Layout Suite XL: Connectivity Driven Editing User Guide -- Make Cell (cadence.com)
    In the scenario you describe you could make the 'half cell' a transparent instance and the binder will descend the hierarchy and update xl-compliance (instance and net binding).
  • A1vis
    A1vis over 3 years ago in reply to RobMan
    Sorry for the late reply... The previously inferred net name seems to be meddling with the binding process. I'm still trying these guides.
