  3. [Solved] Cannot Direct Plot PAC Current (Even though it...
  • Views 8192
[Solved] Cannot Direct Plot PAC Current (Even though it is saved in outputs!)
MahdiMohammadi
MahdiMohammadi over 2 years ago
I cannot direct plot the output the drain current of a transistor in my PAC analysis. This is while I can plot the voltage of the same node, and I have added the corresponding node as output and selected the save option.
I get the "Error: ...... is not a kept output" error.
Best,
Mahdi
    Andrew Beckett over 2 years ago +1
    Mahdi, Set useprobes to yes on the Outputs→Save All forum: You should also think about moving to ADE Explorer (you're using ADE L) since ADE L is obsolete. That won't address this issue, but I just…
    Mahdi,
    You should also think about moving to ADE Explorer (you're using ADE L) since ADE L is obsolete. That won't address this issue, but I just noticed that you're using ADE L and thought I should point it out.
  • MahdiMohammadi
    MahdiMohammadi over 2 years ago in reply to Andrew Beckett
    Thank you, Andrew! It works now.
