  3. Using ESC key to close a dialog?
  • Views 9658
StephanWeber
StephanWeber over 2 years ago
in most programs pressing Esc is like clicking to Close or Cancel button. And enter is equal to Apply.
Can I set some internal variable this that that also ADE, Composer, etc. follows this convention?
Bye Stephan
    That's the convention in Virtuoso too (well, enter does an "OK" - strictly it uses the default button on the form). So I'm not sure why you would have to set a variable to enable this?
  • StephanWeber
    StephanWeber over 2 years ago in reply to Andrew Beckett
    Should it also work for ESC? This is not my impression. Usally the dialog remains open, even when pressing ESC.
    Andrew Beckett over 2 years ago in reply to StephanWeber
    Yes. Is it a specific "dialog" that you're referring to? Maybe there's some specific dialog implemented in native Qt that might not behave this way, but "hi" forms in general would get cancelled upon pressing escape.
