  3. Mapping the net names of schematic netlist and layout n...
  • Subscribers 137
  • Views 7610
Mapping the net names of schematic netlist and layout netlist
DEEPWATER
DEEPWATER over 2 years ago
Through the LVS process, we can extract the schematic netlist and layout netlist.
In the schematic netlist and layout netlist extracted by this process, the net name may be different even for the same net.
Are there any ways to match the layout netlist's net name and the schematic netlist's net name?
thanks
    Match how? You mean to guide LVS? Given that LVS works on non-connectivity layout data, it derives the nets itself and I'd expect nets to match - how else are they being named? Which LVS tool are you using? What exactly are you asking (and for what purpose)?
  • Shawn Daniel Rodrigues
    Shawn Daniel Rodrigues over 2 years ago in reply to Andrew Beckett
    Hi, I'm having the same doubt, the device/net name in the extview file from assura QRC isn't same as the instance name in the layout.
    eg: the name in extview is avC7 and not the instance name like (MP2)
