  3. Regarding floorplan design
  • Subscribers 97
  • Views 10627
anyoumus
anyoumus over 2 years ago
Hello Everyone,
Im facing lot of issue while design floorplan so there is some question regarding this
1. how to design floorplan file
2. how to design DEF file.
3. how to generate .fp file and at what stage we generate. what the procedure we follow to generate the file.
4. what is .fp.spr file and where its is used.
Please reply this question in brief with if any supportable documents and link please attache it.
    ShawnLogan over 2 years ago
    Dear anyoumus,
    There is a Cadence blog that includes a link to the Floorplanning User Guida and a Rapid Adoption Kit (RAK) at:
    https://community.cadence.com/cadence_blogs_8/b/cic/posts/custom-ic-design-flow-methodology-circuit-layout
    These might be good resources to consider reviewing.
    Shawn
  • anyoumus
    anyoumus over 2 years ago in reply to ShawnLogan
    Thanks for your reply ShawnLogan,
    My question toward only back-end related in digital design (Physical design).
    All the above question related to genus and innovus tool.
    could you specified the answer more towards relate this tools.
    Andrew Beckett over 2 years ago in reply to anyoumus
    You should have asked your question in the Digital Implementation forum, not the Custom IC Design forum. I'll move your post to the right place.
  • anyoumus
    anyoumus over 2 years ago in reply to Andrew Beckett
    i Already asked in digital implementation forum.
    for your reference i attached the snippet.
    OK, well the forum guidelines ask you not to double-post the same question in more than one forum.
    However, to be fair, I just noticed that these are no longer pinned for some reason - they should be listed at the top of the posts. I'll check that with our IT team.
  • anyoumus
    OK Andrew I will deleted one post .
