  3. Adjusting circuit parameters led to the failure of Spectre...
  • Views 5883
Adjusting circuit parameters led to the failure of Spectre simulation
liangqunshan
liangqunshan over 2 years ago
Hi,all!
I encountered a problem: when the simulator selects Spectre for simulation, it can run normally, but if the simulator selects APS, it cannot simulate, as shown in the following figure:
As the image may be compressed and become blurred during the upload process, I have imported the image into the document to avoid this issue.
the Output log Prompts When using APS.docx
Why does this happen? And how can I solve it?
    I suggest you contact customer support. Screenshots of log files aren't very helpful (posting the actual log files would be more useful), but even so this need an application engineer to see the actual testcase.
