  3. Run multiple same type analysis in IC 23.1 ADE
  • Subscribers 132
  • Views 6858
SimbaG
SimbaG over 1 year ago
My virtuoso:
virtuoso -V
@(#)$CDS: virtuoso version IC23.1-64b 06/21/2023 09:33 (cpgbld16) $
Is there a better way for running multiple analysis? E.g. multiple stb at a specified tran anaylsis time.
Context: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVpVEAU
And many discusstions on this forum. (Just list some for the sake of future)
Multiple STB on tran
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/41447/how-to-setup-and-run-multiple-stb-simulation-in-a-single-state
Multiple PAC on PSS:
https://community.cadence.com/cadence_technology_forums/f/rf-design/42630/running-multiple-pac-simulations-on-the-same-pss-analysis
Multiple noise analysis:
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/48294/multiple-noise-analysis-in-one-test
I also have some following questions:
1. if I have more than one ac analysis, will the "VF" function always refer to the default name one? I tried, it seems like is true.
https://support.cadence.com/apex/techpubDocViewerPage?xmlName=vivaxlug.xml&title=Virtuoso%20Visualization%20and%20Analysis%20XL%20User%20Guide%20--%20Calculator%20Functions%20-%20Calculator%20Functions&hash=pgfId-1234892&c_version=IC23.1&path=vivaxlug/vivaxlugIC23.1/appD.html#pgfId-1234892
We can find vfreq in the User Guide, but there is not VF. Is VF deprecated? If there are more than one ac analysis, we have to use vfreq function.
What is the difference between "VF("/SIGNAL")" and "vfreq('ac /SIGNAL)"?
(Same question on VT and vtime)
2. Can we do it in ADE Assembler by share transient data between multiple Explorer Tests?
Another work around for the multiple ac analysis is by having multiple Explorer Tests in the ADE Assembler. But if actimes is needed, we have to run multiple tran analysis.
Is there a way to share the data, so that we can have multiple ac analysis and no need to reduplicate tran analysis?
Thank you!
  • JankoK
    JankoK over 1 year ago
    Hi SimbaG,
    You actually answered to a few questions yourself with your links... Anyway, what's the motivation for running multiple ac analyses? Do you want to run them at the same time point of your transient? Otherwise, you can use actimes and run as many as you want at different time points. If you are just running standalone ac, just do it in multiple tests, no need to complicate stuff. You also get the benefit of parallelization (over multiple jobs)...
    1. I think that vfreq() is like an extension. It can be used with other analyses too, like hb, pss, qpss, pac, hbac... and you can also specify a frequency to get the voltage at that frequency. VF() is just for ac. You can find the description in Virtuoso ADE SKILL Reference. It's similar for vtime() and VT(), vtime() also works with pss and hb, and you can specify a time point.
    2. Ok, now I got it, you are running a long transient... I guess you could use Save-Recover and recover somewhere close before your ac time. So, first test runs a transient, saves it, second, third... recover close to actimes.
    Hope this helps!
    BR
    /Janko
  • Frank Wiedmann
    Frank Wiedmann over 1 year ago in reply to JankoK
    I would also guess that VT() and VF() are much older, probably predating SpectreRF. Multiple pnoise analyses are supported by ADE, see https://support.cadence.com/apex/techpubDocViewerPage?path=spectreRFinExplorer/spectreRFinExplorer23.1/Chap4.html#pgfId-1139352 and of course you can always use calcVal() to combine the results of several tests, see https://support.cadence.com/apex/articleattachmentportal?id=a1O0V0000067A0ZUAU
  • SimbaG
    SimbaG over 1 year ago in reply to JankoK
    Thank you for your reply.
    I am expecting that IC 23.x can provide a GUI to do so. At least, cadence bump version number a lot. And those discuesstion are a few years  ~ ten years ago, they might outdated.
    So, currently at IC 23.1, we still have to have a scs file rather than a GUI in Virtuoso ADE.
    And for VF and VT, if we use custom scs file they may not work, (it will refer to the default name one).
  • SimbaG
    SimbaG over 1 year ago in reply to Frank Wiedmann
    Thank your Frank.
    Andrew Beckett over 1 year ago in reply to SimbaG
    The VF function is not deprecated - it's still documented: Virtuoso ADE SKILL Reference -- VF - VF
    The need to better support multiple analyses of the same time is well understood, but it's a fairly significant architectural change in ADE for which there was some work done a few years ago, but a stumbling point at the time was that the calculator access functions needed to make it easier to access the results of the additional analyses. You can do this easily enough by using v("/someNode" ?result "ac2-ac") where "ac2" is the instance name of the analysis in your included file. You can check the names by using the results browser.
