  3. Could anyone explain PSS+PAC simulation result of sampling...
  • Subscribers 137
  • Views 2808
Could anyone explain PSS+PAC simulation result of sampling circuit
fvoisin
fvoisin over 2 years ago
Hi, the answer to my question is certainly trivial, I perform a PSS+PAC analysis to simulate the response of a sampling circuit made up of an ideal switch (RonSW=200 ohms) followed by a capacitance of CT=80pF.  When the switch is continuously on, I obtain a cutoff frequency at -3dB of 10MHz which corresponds to the expected value while when the switch is clocked at the frequency of 50MHz the cutoff frequency is divided by two, i.e. 5MHz. I suspect that this is due to spectral aliasing but I do not understand the division by a factor of two of the bandwidth. Could anyone give me an explanation ?
  • Frank Wiedmann
    Frank Wiedmann over 2 years ago
    In the switched version, the current through the resistor is only flowing half of the time, so its resistance is effectively doubled. You might want to look up "state-space averaging".
  • fvoisin
    fvoisin over 2 years ago in reply to Frank Wiedmann
    Thank you very much Frank for your answer.
