  3. Create schematic from netlist(verilog)
  • Subscribers 136
  • Views 3779
SimhanAnalog
SimhanAnalog over 2 years ago
I am looking to create a schematic from a netlist(verilog) file. The verilog file just has connections of different modules. It doesnt have any logic(behaviouiral verilog code).
Example:
Say I have a cell sample_core which has a symbol view. Among other input and output ports it also has 4 outputs o_w,o_x,o_y,o_z each 7:0.
I want to create a sample_wrap cell which does some rewiring of sample_core. But I dont want to do it manually in schematic. So I will create a verilog file that does the rewiring and want to generate a schematic and symbol views from the verilog. Example given below.  This verilog file I will generate using some script to avoid mistakes.
module sample_wrap
//some many other inputs and outputs
output [3:0] o_a,
output [3:0] o_b,
output [3:0] o_c,
output [3:0] o_d,
output [3:0] o_e,
output [3:0] o_f,
output [3:0] o_g,
output [3:0] o_h
sample_core I_sample_core
.o_w({o_h[0],o_g[0],o_f[0],o_e[0],o_d[0],o_c[0],o_b[0],o_a[0]}),
.o_x({o_h[1],o_g[1],o_f[1],o_e[1],o_d[1],o_c[1],o_b[1],o_a[1]}),
.o_y({o_h[2],o_g[2],o_f[2],o_e[2],o_d[2],o_c[2],o_b[2],o_a[2]}),
.o_z({o_h[3],o_g[3],o_f[3],o_e[3],o_d[3],o_c[3],o_b[3],o_a[3]}),
endmodule
    Did you have a question? You can use File→Import→Verilog in Virtuoso to import the verilog and create a schematic, if that is what you meant to ask.
  • SimhanAnalog
    SimhanAnalog over 2 years ago in reply to Andrew Beckett
    Yes. This is what I was looking for. Thanks. One observation is that the import verilog option doesnt support system verilog construct. Like if my sample_wrap.sv file had the following
    module sample_wrap
    output logic [3:0] o_a,
    output logic [3:0] o_b,
    output logic [3:0] o_c,
    output logic [3:0] o_d,
    output logic [3:0] o_e,
    output logic [3:0] o_f,
    output logic [3:0] o_g,
    output  logic [3:0] o_h
    endmodule
    It says import failed since it doesnt recognize the "logic" term. Is there some flag that we can give to the tool to recognize this?
