  3. ADE Schemetic simulation will not auto re-netlist Verilog...
  • Subscribers 137
  • Views 6238
ADE Schemetic simulation will not auto re-netlist Verilog-A Module
SimbaG
SimbaG over 2 years ago
When I edit the Verilog-A module which referred in schemetic, the ADE simulation environment will not auto-update the netlist until I open the Verilog-A module -> Extract.
Seems like the Spectre will refer to the netlist.oa file rather than the .va file in the netlist cell view.
Is there a work around that auto update it? Should I consider use config view to do so?
    Spectre doesn't look at the netlist.oa - that will however impact the incremental netlist, so it's possible that it won't notice parameter or pin name changes etc and the instance won't get renetisted. Since however the netlist includes the path to the veriloga.va I wouldn't expect it to look at anything else.
    Without knowing the specifics of what is going wrong, it's hard to say, but you quite frankly should never directly edit the file. That's not a supported flow.
  • SimbaG
    SimbaG over 2 years ago in reply to Andrew Beckett
    I edit it via Virtuoso Verilog-A Editor, and click save rather than extract.
    The simulation will not be updated based on new .va file. Until I click extract and re-run the simulation.
    Is there a way to notify incremental netlist that the .va file has been updated?
  • Frank Wiedmann
    Frank Wiedmann over 2 years ago in reply to SimbaG
    You might try if the command-line option mentioned in https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V0000090zjSUAQ helps in your case.
