  3. Fail LVS extraction
  • Subscribers 136
  • Views 6522
Fail LVS extraction
BARID
BARID over 2 years ago
Hello everyone,
I did a layout of a schematic circuit and I passed the DRC test but I can't seem to launch the layout versus schematic test because it fails to generate the netlist everytime. I have the error "Schematic export failed or was cancelled. Please consult the transcript in the viewer window". It's especially weird because my collegue helped me and I did the same steps as him but I get the error and not him.
The skill consol indicates that there is an error in netlist procedure :
"*ERROR* Error Detected in netlisting, netlist bypass flag set.
*ERROR* Could not find netlist procedure : 'ansCdlCompPrim_b55x'
component : npnxhs
named : /Q0
in cellview : schetest/schematic
of library : test
  • RobMan
    RobMan over 2 years ago
    The PDK environment is not loaded correctly. The ansCdlCompPrim_b55x netlist procedure is not defined.
    Which PDK are you using?
  • BARID
    BARID over 2 years ago in reply to RobMan
    The PDK of BiCMOs55x of Stmicroelectronics : PDK_STM_BICMOS055X
  • RobMan
    This is defined in '$DKITROOT/DATA/PLIB/PLIB.simrc'
    Loaded from PDK_STM_BICMOS055X.simrc.
    Assuming you have these files in the PDK you need fix PDK environment setup.
