  3. Combining Histograms of Multiple Tests
  • Subscribers 136
  • Views 4389
HongJian
HongJian over 2 years ago
I am trying to plot the histogram of difference of Vout from two different tests under the same Monte Carlo runs. It is similar to this post Combining Histograms of Multiple Tests? - Custom IC Design - Cadence Technology Forums - Cadence Community.
1st Attempt:
Expression
histogram2D(list(_statGetWaveform("vout_cm" nil ?resDbFile axlGetHistoryResults(axlGetCurrentHistory(_vivaGetSessionName())) ?testName "TEST1" ?filtPointsList "" ) _statGetWaveform( "vout_cm" nil ?resDbFile axlGetHistoryResults(axlGetCurrentHistory(_vivaGetSessionName())) ?testName "TEST2" ?filtPointsList "" ) ) 10 "standard" "stddev" t t )
Result
Error
2nd Attempt:
Expression
Result
Valid data not found for "vout_cm", check expression and/or filter settings.
ERROR (VIVA-3002):expression evaluation failed: Expression evaluates to nil
ERROR (VIVA-3002):expression evaluation failed: _statGetWaveform("vout_cm" nil ?resDbFile axlGetHistoryResults(axlGetCurrentHistory(_vivaGetSessionName())) ?testName "TEST1" ?filtPointsList "" )
3rd Attempt:
Expression
_statGetWaveform(v("vout_cm" ?result "dcOp") nil ?resDbFile axlGetHistoryResults(axlGetCurrentHistory(_vivaGetSessionName())) ?testName "TEST1" ?filtPointsList "" )
Result
ERROR (VIVA-3002):expression evaluation failed: val is not legal.
ERROR (VIVA-3002):expression evaluation failed: _statGetWaveform(v("vout_cm" ?result "dcOp") nil ?resDbFile axlGetHistoryResults(axlGetCurrentHistory(_vivaGetSessionName())) ?testName "TEST1" ?filtPointsList "" )
Note
I already selected Save Simulation Data and the results browser is showing these values.
