  3. Cell layout bigger than PR Boundary
  • Subscribers 136
  • Views 7071
MahdiMohammadi
MahdiMohammadi over 2 years ago
I just designed the layout of a cell in Layout Suite, and I put a pr boundary object around the design.
When I try to use the cell in a new layout, the cell seems to have an extra empty space on the top of it, as if there's an invisible component hidden there.
The cell layout:
The layout when I use the cell in another layout:
All layers are visible, and when I press Ctrl+A I cannot find anything being marked there.
Also, when I press F in the cell layout, the window zooms as if there's something on the top.
I'd appreciate your suggestions.
Best regards,
Mahdi
    See Reason for cell's large-sized boundary or bounding box aka bBox area or extent of layout. SKILL to delete steiners, markers, guides, remove invisible ghost layers, shapes.
