  3. XL Compliance
  • Subscribers 136
  • Views 5158
XL Compliance
LW202409248018
LW202409248018 over 2 years ago
Hi,all
   I encountered an issue where the same layout displays different XL compliance results across different versions. In version IC6.1.7-64b.500.22, it shows 100%, while in version IC6.1.8-64b.500.13 , it only shows 88%. Additionally, areas that have already been connected are indicated as open circuit。The error message is as follows; however, the connection has already been established.The LVS and DRC processes have been successfully completed.
Open on net 'avdd' between:
- InstTerm of terminal 'S' of instance 'M62'
- InstTerm of unimplemented terminal 'B' of instance 'M62'
  • Alex Soyer
    Alex Soyer over 2 years ago
    It is possible that we have some additional checks added.
    In the Option > Connectivity form go to Connectivity tab> Annotations > Incomplete Nets
    Turn OFF Unimplemented instance pins.
    The open should disappear.
    Alex
  • LW202409248018
    LW202409248018 over 2 years ago in reply to Alex Soyer
    First of all, thanks, but nothing has changed after Turn OFF Unimplemented instance pins. The Open still exists.
