  3. Importing PSPICE .lib file into Virtuoso
  • Subscribers 136
  • Views 7475
IP202410071719
IP202410071719 over 2 years ago
I'm trying to use a PSPICE model of a FET prediver chip in my test bench (UCC20225_TRAN, provided by T.I.) but cannot get the tool to succesfully netlist.
Appreciate this has been covered before (see below for example) but I'm haviong no joy with the specified method:
community.cadence.com/.../importing-pspice-or-ti-models-into-cadence-virtuoso
You should reference the model either via the "PSpice Files" section of the Setup->Simulation Files in ADE or by creating a pspice view and pasting the model in that way (setting the view type as "Pspice" when creating the new view, and then switching into that view using either the view list or a config). Don't just include it as normal SPICE (because it's not - there's an explicit approach for including pspice models in spectre because they have additional syntax beyond Berkeley SPICE).
When I follow the guidance above  and create a Pspice cell view behind my symbol (into which I paste the PSPICE model), I am unable to 'build a database....' without getting a parsing error as below:
Fatal error found by parser during PSPICE read-in.
Fatal: MTS mode must be enabled for netlist with `pspice_include'. Add `+mts' at the Spectre command line and rerun the simulation.
I'm not sure how to address this. Any guidance gratefully received.
Cheers.
    Which Spectre version are you using? +mts has been the default for a while, so I don't think this should be an issue with current Spectre versions.
  • IP202410071719
    IP202410071719 over 2 years ago in reply to Andrew Beckett
    I'm embarrased to admit that, at the core of my issue, was a typo Slight smile
    The name of my cellview and the name of the subcircuit defined in the pspice file were out by one lower/upper case letter.
    Not sure why that should have caused the MTS related error to appear but, by resolving the typo, I can now netlist and simulate my PSPICE model.
    Thanks for the quick response!!!
