  3. Installscape issue on Rocky linux8/9 and Almalinux 9
  • Views 3880
CB202409064221
CB202409064221 over 1 year ago
I'm trying to do a new installation on a dedicted server in the cloud. The OS is Rocky linux.
Once I download istallscape and run the iscape.sh, the GUI open but it is blank.
I installed Java
sudo dnf install epel-release -y
sudo dnf config-manager --set-enabled crb
sudo dnf install java-1.8.0-openjdk java-1.8.0-openjdk-devel -y
sudo alternatives --config java
sudo alternatives --config javac
this is the snapshot of the black gui
Any idea of what could be the issue?
thanks
  • SM202501312649
    SM202501312649 over 1 year ago
    Hello, I'm trying to do a new installation on a dedicted server in the cloud. The OS is Rocky linux. Once I download istallscape and run the iscape.sh, the GUI open but it is blank. I installed Java sudo dnf install epel-release -y sudo dnf config-manager --set-enabled crb sudo dnf install java-1.8.0-openjdk java-1.8.0-openjdk-devel -y sudo alternatives --config java sudo alternatives --config javac this is the snapshot of the black gui
    Andrew Beckett over 1 year ago in reply to SM202501312649
    Two different users with identical posts (I assume you're really the same person but with two different user ids). Anyway, this looks the same as:
    InstallScape presents a blank screen with RDP protocol
    Are you using RDP for the remote display? Can you try using VNC, Exceed TurboX or some other remote display tool to connect to the machine?
  • CB202409064221
    CB202409064221 over 1 year ago in reply to Andrew Beckett
    Hello Andrew, thank you.
    I was able to install VNC and get to Virtuoso up and running with license.
    I see now this error:
    *WARNING* (CMGR-7001): Can't find installation roots
    *Error* (AMS-2910): Cannot create a netlist using the AMS Unified netlister because the required AMS library is not found in the Virtuoso installation path. Check the Virtuoso installation path by running the 'getShellEnvVar("PATH")' command in CIW and ensure that a valid AMS library exists in the tools/affirma_ams/lib/64bit directory in this path.
    Where do i find the AMS library?
    thanks,
    Christian
