  3. Display packet information 'display' not found.
  • Replies 26
  • Subscribers 136
  • Views 11789
rtyuy
rtyuy over 1 year ago
Dear friends,
I am new to the cadence and using the version IC618.  In cadence virtuoso, when  i am trying to open the pcell layout of any cell.  i got the following warnings and see nothing in the layout xl window expect square box.
*WARNING* The display packet information 'pin_drawing' for 'display' was not found.
*WARNING* The display packet information 'pin_label' for 'display' was not found.
*WARNING* The display packet information 'annotate_drawing' for 'display' was not found.
*WARNING* The display packet information 'snap_drawing' for 'display' was not found.
*WARNING* The display packet information 'Row_drawing' for 'display' was not found.
*WARNING* The display packet information 'Unrouted_drawing' for 'display' was not found.
*WARNING* The display packet information 'Group_drawing' for 'display' was not found.
*WARNING* The display packet information 'border_drawing' for 'display' was not found.
Can any one please help me that how can i rectify this problem ???
    Andrew Beckett over 1 year ago in reply to rtyuy +1
    OK, so that's the problem. The file is owned by a user with uid=1966, and gid=1965, and only users with that uid or gid can read the file. You are uid=1009 and gid=1009, so there's no "world" or "other…
    Well, clearly the permissions are not correct for these files as I said. You need to run the "chmod" commands that I mentioned before (as root) - this will change the permissions to -rw-r--r-- (note the…
  • rtyuy
    Dear cadence team,
    i am using cadence virtuoso  version: IC6.1.7. When i am trying to open the layout of any in built cell, i got the warning " The display packet information 'M6_drawing' for 'display' was not found." There are more than 70 warning  for all the layers of layout. Can you please  help me with this??
    This means that it hasn't found a display.drf file with the definition of that packet. The technology library you are using is defining a layer-purpose pair (presumably M6 drawing) that specifies a particular packet name. The display.drf for a PDK would often be loaded at startup or first access, but maybe not in this case. It may just be looking for it in one of the standard places (typically working directory, home directory and a few others - as defined by the setup.loc file).
  • RobMan
    RobMan over 1 year ago
    Which foundry pdk are you using?
    Display packet information is defined in the display.drf file supplied with the pdk. Typically this is loaded in the libInit.il file in the process techlib directory. If a copy exists int he workarea this will be used.
  • rtyuy
    rtyuy over 1 year ago in reply to RobMan
     RobMan , Thank you for the response ..  i am using tsmc65 and recently installed it. i don't know where the problem occurs
  • rtyuy
    rtyuy over 1 year ago in reply to rtyuy
    Dear RobMan , yes i have  dispay.drf file in techfile folder. but where i have to copy it. can you please tell me ??
  • rtyuy
    rtyuy over 1 year ago in reply to Andrew Beckett
    Thank you  Andrew Beckett , display. drf file is already there in the pdk installation path but don't know why this warning occur and what to  do the next!!
  • RobMan
    RobMan over 1 year ago in reply to rtyuy
    A quick fix would be to copy it to your working directory.
    TSMC typically use libInit.il to load. Look in <PDKpath>/tsmcN65/libInit.il. Search for display.drf and check it's loaded.
  • rtyuy
    RobMan , when i checked liblnit.il , this content is writtten in the file .
        ;Load display file ----------------------------------------------------------------------
        filePath = sprintf(nil "%s/display.drf" getWorkingDir())
        if( isFile( filePath) then
           printf("Loading Working place Display File '%s'\n" filePath)
        else
           filePath = sprintf(nil "%s/../display.drf" libPath)
           when( isFile(filePath)
               when( isCallable( 'drLoadDrf)
                   printf("Loading PDK Display File '%s'\n" filePath)
                   drLoadDrf(filePath)
          );when(drLoadDrf)
        );when(isFile)
        );if(isFile)
  • RobMan
    Yes, so this loads the display.drf from the working directory or the directory above the library path.
    If the display.drf is loaded and you still get errors then the techlib and display information are potentially out of sync. i.e. Layers have been added to the techlib but no corresponding update to the display information. Any undefined layers will appear yellow on the canvas.
  • rtyuy
    RobMan  , Yes the above error is removed after copying the display.drf file in my working directory . However when i try to do "generate from source" i got the error "pcell evaluation failed". Please suggest how to rectify this problem.
    thank  you
