  3. Display packet information 'display' not found.
  • Replies 26
  • Subscribers 136
  • Views 11790
rtyuy
rtyuy over 1 year ago
Dear friends,
I am new to the cadence and using the version IC618.  In cadence virtuoso, when  i am trying to open the pcell layout of any cell.  i got the following warnings and see nothing in the layout xl window expect square box.
*WARNING* The display packet information 'pin_drawing' for 'display' was not found.
*WARNING* The display packet information 'pin_label' for 'display' was not found.
*WARNING* The display packet information 'annotate_drawing' for 'display' was not found.
*WARNING* The display packet information 'snap_drawing' for 'display' was not found.
*WARNING* The display packet information 'Row_drawing' for 'display' was not found.
*WARNING* The display packet information 'Unrouted_drawing' for 'display' was not found.
*WARNING* The display packet information 'Group_drawing' for 'display' was not found.
*WARNING* The display packet information 'border_drawing' for 'display' was not found.
Can any one please help me that how can i rectify this problem ???
    Andrew Beckett over 1 year ago in reply to rtyuy +1
    OK, so that's the problem. The file is owned by a user with uid=1966, and gid=1965, and only users with that uid or gid can read the file. You are uid=1009 and gid=1009, so there's no "world" or "other…
    Well, clearly the permissions are not correct for these files as I said. You need to run the "chmod" commands that I mentioned before (as root) - this will change the permissions to -rw-r--r-- (note the…
    This sounds as if something is seriously messed up with the PDK installation. It sounds as if it's (maybe) not loading the context files containing the underlying functions used within the PCell. This might be the same reason that the display.drf isn't loaded.
    Have you by any chance renamed the tsmcN65 library? There is code in the libInit.il that assumes the library is called tsmcN65 and if you've named it something else for some reason, this will fail to work.
    Debugging a "pcell evaluation failed" error without an indication of the actual error is rather hard, but this is definitely not normal.
    I suggest you contact ASK (customer support) by logging in at http://support.cadence.com and then using the Case menu to submit a support case.
  • rtyuy
    rtyuy over 1 year ago in reply to Andrew Beckett
    Dear Andrew Beckett , Thank you for the response but i have not renamed tsmcN65 library.
    If you start a fresh virtuoso session, and then in the library manager you click on the tsmcN65 library (maybe right mouse->properties) do you get something like this in the CIW:
    Initializing from libInit.il for library tsmcN65...
    -- tsmcN65_updateCDFs.il
    -- amsNetlister.ile
    -- tsAbutFunction_cdn.ile
    -- tsmc_esti.ile
    -- pnp.cbe
    -- npn.cbe
    -- npn_mis.cbe
    -- pnp_mis.cbe
    -- tsmcN65Tool.cxt
    -- tif_tcf_crn65lp_v1.2a_patchA.cxt
    -- tsmcN65.cxt
    (this is from a very old tsmcN65 PDK I happened to have locally).
    As I said, contacting customer support is almost certainly the best choice here - it's very hard to debug odd things like this over a forum.
  • rtyuy
    Dear Andrew Beckett , actually i cannot take cadence support  help due to non availability of HOST ID. However when i have click on properties . i got
    -- /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/pcellCode.cdn
    -- /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/pcellCode1.cdn
    -- /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/pcellCode2.cdn
    -- /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/pcellCode3.cdn
    -- /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/pcellCode4.cdn
    -- /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/pcellCode5.cdn
    -- /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/mom.cdn
    -- tsmcPdkParamTable.il
    -- tsmc_esti.ile
    -- tsmcN65Tool.cxt
    *Error* loadContext: could not open file - "/home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/64bit/tsmcN65Tool.cxt"
    Does that file exist and do you have the permissions to read it? I'm pretty certain it must exist since the libInit.il in TSMC PDKs usually just use a getDirFiles() to determine what to load, but maybe there's an issue with the permissions.
    Looking back, I wonder whether the display.drf within the PDK didn't get used because there's already one in the working directory (that takes priority from the code you mentioned earlier). My (old) copy of the tsmcN65 library (maybe a different process variant anyway) doesn't contain that code, but if it looks like you showed, the working dir's display.drf would win.
  • rtyuy
    Andrew Beckett yes i have an access to the root  and have permission to the files
    Can you please do this in a terminal window and report the results:
    ls -l /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/64bit/tsmcN65Tool.cxt
    ls -l /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/tsmcN65/../skill/tsmcN65Tool.cxt
  • rtyuy
    Andrew Beckett ,i am  getting below information
    1. -rw-r-----. 1 1966 1965 2410497 Sep  3  2012 /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/skill/64bit/tsmcN65Tool.cxt
    2.-rw-r-----. 1 1966 1965 1555223 Sep  3  2012 /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/skill/tsmcN65Tool.cxt
    Can you also share the output of "id" too (in the terminal)?
  • rtyuy
    can you please tell.. what "id" means??
