  3. Display packet information 'display' not found.
  • Replies 26
  • Subscribers 136
  • Views 11805
rtyuy
rtyuy over 1 year ago
Dear friends,
I am new to the cadence and using the version IC618.  In cadence virtuoso, when  i am trying to open the pcell layout of any cell.  i got the following warnings and see nothing in the layout xl window expect square box.
*WARNING* The display packet information 'pin_drawing' for 'display' was not found.
*WARNING* The display packet information 'pin_label' for 'display' was not found.
*WARNING* The display packet information 'annotate_drawing' for 'display' was not found.
*WARNING* The display packet information 'snap_drawing' for 'display' was not found.
*WARNING* The display packet information 'Row_drawing' for 'display' was not found.
*WARNING* The display packet information 'Unrouted_drawing' for 'display' was not found.
*WARNING* The display packet information 'Group_drawing' for 'display' was not found.
*WARNING* The display packet information 'border_drawing' for 'display' was not found.
Can any one please help me that how can i rectify this problem ???
    Andrew Beckett over 1 year ago in reply to rtyuy +1
    OK, so that's the problem. The file is owned by a user with uid=1966, and gid=1965, and only users with that uid or gid can read the file. You are uid=1009 and gid=1009, so there's no "world" or "other…
    Well, clearly the permissions are not correct for these files as I said. You need to run the "chmod" commands that I mentioned before (as root) - this will change the permissions to -rw-r--r-- (note the…
    It's a UNIX command that shows the user id information (user id and group id information).
    If you don't want to share that, try using:
    chmod o+r /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/skill/64bit/tsmcN65Tool.cxt
    chmod o+r /home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/skill/tsmcN65Tool.cxt
    (as user "1966") and then see whether it works. I'm just trying to ensure that you have read permission on the files.
  • rtyuy
    rtyuy over 1 year ago in reply to Andrew Beckett
    OUTPUT OF ID COMMAND:
    uid=1009(parminder) gid=1009(parminder) groups=1009(parminder) context=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023
    OUTPUT OF CHMOD COMMAND:
    1.chmod: changing permissions of '/home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/skill/64bit/tsmcN65Tool.cxt': Operation not permitted.
    2.chmod: changing permissions of '/home/MSRF_Low_Power/PDK/Cadence_OA/tn65cmsp007k3_1_7a/skill/tsmcN65Tool.cxt': Operation not permitted
    OK, so that's the problem. The file is owned by a user with uid=1966, and gid=1965, and only users with that uid or gid can read the file. You are uid=1009 and gid=1009, so there's no "world" or "other" access to the files. The chmod was trying to fix this, but you need to do this as a user that has UNIX permission to change the permissions (either uid=1966 or as root).
    It's a pure UNIX permission issue here, nothing really to do with Cadence tools.
  • rtyuy
    i have installed the pdk  in the root, but  other users can acess the file and read it.
    so what permission i need to change then ??  can you please suggest , i  can make the changes in the root as i have password.
    Well, clearly the permissions are not correct for these files as I said. You need to run the "chmod" commands that I mentioned before (as root) - this will change the permissions to -rw-r--r-- (note the r in the final "other" triplet). That's what the "o+r" is doing - it's adding "read" access for "others".
  • rtyuy
    Hey Andrew Beckett , Than you so much for giving a suggestion, yes it was just file permission issue. problem is solved now..
    you are just savior for me, i was struggling badly . Thanks a lot once again Relaxed
