  3. Encountering Thermal-1501 in Legato Electrothermal Simu...
  • Subscribers 136
  • Views 3731
Encountering Thermal-1501 in Legato Electrothermal Simulation
AB_1718053087553
AB_1718053087553 over 1 year ago
Hello everyone,
I am running a Legato electrothermal simulation for a 10mmx10mm die area. First, I used both NX and NY to 200, and I can smoothly run the simulation. However, I need a small mesh size for my post-processing algorithm. So, when I try to run the simulation by specifying 10000 both for NX and NY, then, it gives me the Thermal-1501 error. Does anyone have any solution to this problem?
Thank you!
    This error code normally points to a log file to look at. For example:
    ERROR (THERMAL-1501): Found an error when creating thermal database. Please check 'pkg_T3d.log' or 'createThermalDB_error.log' in
    '../psf/' for details.
    Did you look at those files? If that didn't help, I suggest you contact customer support (use the Case menu after logging in to submit a support case).
  • AB_1718053087553
    AB_1718053087553 over 1 year ago in reply to Andrew Beckett
    I already checked the "pkg_T3d.log" but it was just showing me the simulation time and date and nothing else. Also, I couldn't find
    "createThermalDB_error.log", maybe it wasn't generated.
    I will contact customer support. Thank you!
