  3. Unable to run Monte-Carlo simulation on ADE-XL
  • Replies 32
  • Subscribers 136
  • Views 12437
rtyuy
rtyuy over 1 year ago
Dear Friends,
I am using cadence virtuoso  (SUB VERSION: IC6.1.7-64b.500.19 (64-bit addresses)). Earlier Monte Carlo was running fine. but now when i run MC on ADEXL, it is showing following  error :
ADEXL-1921: failed to start new job after 3 attempts . Possible reasons could be
1. The machine selected in the current job set up policy is not reachable
2. The cadence hierarchy is not detected, not installed properly, or not compatible on the machine selected in the current job set up policy.
3. Job start script /home/vlsi2/laxman/.temp_vlsi2/.cmddir0/runICRP17 is not found in the remote machine.
          Do you want to retry with the current set up? Selecting no will abort the current session.
Please  help me in finding the solution  of this problem.
i have  also  tried to change the license but it is still not working.
    Andrew Beckett over 1 year ago +1
    I merged your posts (please read the forum guidelines - the pinned post at the top of each forum - as this tells you not to post duplicate posts in different forums; this will increase the chance of your…
  • rtyuy
    Dear Friends,
    I merged your posts (please read the forum guidelines - the pinned post at the top of each forum - as this tells you not to post duplicate posts in different forums; this will increase the chance of your post being ignored, not reduce it!)
    Anyway, what does your job policy look like? Can you run "virtuoso -nograph" on the machine it is launching to (the current machine if local)?
  • rtyuy
    rtyuy over 1 year ago in reply to Andrew Beckett
    Andrew Beckett , thanks for the response i am unable to get it .It will be very kind of you if you can help me to solve this issue with more details.
    in job policy setup distribution method is local and it was run fine with it ealier from last 2 years.
    do you mean  run  a command  "virtuoso -nograph " on the terminal ???
    Andrew Beckett over 1 year ago in reply to rtyuy
    Yes.
  • rtyuy
     Andrew Beckett , i dont know if i am doing correct , but output comes as follow
    Welcome to Cadence Tools Suite
    [vlsi2@eeiitj123 ~/laxman]$ virtuoso -nograph
    2025/07/19 18:56:22 WARNING This OS does not appear to be a Cadence supported Linux configuration.
    2025/07/19 18:56:22 For more info, please run CheckSysConf in <cdsRoot/tools.lnx86/bin/checkSysConf <productId>
    *WARNING* Could not open display eeiitj123.iitj.ac.in:80.  If no X server is running for this display,
    *WARNING* remove the file /tmp/.X80-lock: owner vlsi2, last modified Fri Jul 18 12:00:30 2025
    Trying another display...
    *WARNING* Could not open display eeiitj123.iitj.ac.in:81.  If no X server is running for this display,
    *WARNING* remove the file /tmp/.X81-lock: owner vlsi2, last modified Fri Jul 18 12:00:48 2025
    You're using a rather old version of Virtuoso (over 7 years old) and since then we've moved to a different way of creating the hidden X display used to support non-graphical mode. The older approach was shared between different sessions and then used locking to avoid things interfering with each other.
    I would suggest that (assuming you don't have any running virtuoso -nograph sessions on the machine) that you do:
    cd /tmp
    ls -al .X*-lock
    having checked these, do:
    rm .X*-lock
    and then try the "virtuoso -nograph".
    Usually it only tries 10 different displays and then gives up - so if they are all locked with stranded locks, it will fail. That's quite likely what is causing the problem.
    Better would be to move to a newer version - at least the latest IC6.1.8 hotfix or better still IC23.1.With IC23.1 you'd have to move to Assembler as ADE XL is no longer available (we've had quite a few years for people to adopt the newer generation ADE tools; it will prompt you to migrate to ADE Assembler if you try to open an adexl view though).
  • rtyuy
    Andrew Beckett , i tried above commands and deleted the files. when i run thre virtuoso -nograph again , following error appears.
    *WARNING* remove the file /tmp/.X11-unix/X81: owner vlsi2, last modified Fri Jul 18 12:00:48 2025
    *WARNING* Could not open display eeiitj123.iitj.ac.in:82.  If no X server is running for this display,
    *WARNING* remove the file /tmp/.X11-unix/X82: owner vlsi2, last modified Fri Jul 18 12:01:43 2025
    *WARNING* Could not open display eeiitj123.iitj.ac.in:89.  If no X server is running for this display,
    *WARNING* remove the file /tmp/.X11-unix/X89: owner vlsi2, last modified Fri Jul 18 12:14:03 2025
    *WARNING* Giving up after trying 10 displays.
    *WARNING* Unable to connect to a non-graphical X Window Display server.
    *WARNING* Try using the -vncTenbase option or the CDS_XVNC_TENBASE environment variable to specify a different set of 10 displ
    Try running "cdsXvnc" and seeing if that reports any errors.
    What OS are you running on (try running "lsb_release -a")?
  • rtyuy
    Andrew Beckett
    OS INFORMATION
    LSB Version:    :core-4.1-amd64:core-4.1-ia32:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-ia32:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-ia32:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch
    Distributor ID:    CentOS
    Description:    CentOS Linux release 7.9.2009 (Core)
    Release:    7.9.2009
    Codename:    Core
    I saw this (before you added a mention of me just now), but you didn't answer my other question:
