  3. Unable to run Monte-Carlo simulation on ADE-XL
  • Replies 32
  • Subscribers 136
  • Views 12438
rtyuy
rtyuy over 1 year ago
Dear Friends,
I am using cadence virtuoso  (SUB VERSION: IC6.1.7-64b.500.19 (64-bit addresses)). Earlier Monte Carlo was running fine. but now when i run MC on ADEXL, it is showing following  error :
ADEXL-1921: failed to start new job after 3 attempts . Possible reasons could be
1. The machine selected in the current job set up policy is not reachable
2. The cadence hierarchy is not detected, not installed properly, or not compatible on the machine selected in the current job set up policy.
3. Job start script /home/vlsi2/laxman/.temp_vlsi2/.cmddir0/runICRP17 is not found in the remote machine.
          Do you want to retry with the current set up? Selecting no will abort the current session.
Please  help me in finding the solution  of this problem.
i have  also  tried to change the license but it is still not working.
    Andrew Beckett over 1 year ago +1
    I merged your posts (please read the forum guidelines - the pinned post at the top of each forum - as this tells you not to post duplicate posts in different forums; this will increase the chance of your…
  • rtyuy
    rtyuy over 1 year ago in reply to Andrew Beckett
    Andrew Beckett  please find
    Welcome to Cadence Tools Suite
    [inder@eeiitj123 ~/parm_tsmc65]$ cdsXvnc
    cdsXvnc: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
    Andrew Beckett over 1 year ago in reply to rtyuy
    OK, that means this machine needs to have another package installed (this is why -nograph is failing). The RPM (on my RHEL7.6 machine) is:
    compat-libstdc++-33-3.2.3-72.el7.i686
    I can see this from:
    myuser> rpm -q -f /usr/lib/libstdc++.so.5
    You might also want to consider moving to a more recent IC version - for example the latest IC6.1.8 hotfix (ISR36). cdsXvnc is no longer used in the later IC6.1.8 versions.
  • rtyuy
    Thank you for the response andrew, , actually right now the person who install cadence is not present in the lab so cant move to recent version.
    however can you please explain more about the package need to install, may be it help somewhat
    The package (RPM) is called compat-libstdc++ - you'd need to install this on the OS using yum, rpm or whatever is normally done. You'll need whoever looks after the OS (with root access) to do this. Anyone who knows about Linux admin should know what these packages are.
  • rtyuy
    Andrew Beckett  , i have installed the package
    user> rpm -q compat-libstdc++-33
    compat-libstdc++-33-3.2.3-72.el7.x86_64
    but when i run "cdsXvnc" again, i get
    user> cdsXvnc
    but if run
    root> sudo find / -name libstdc++.so.5 2>/dev/null
    /home/install/IC617/tools.lnx86/lib/64bit/libstdc++.so.5
    /home/install/IC617/tools.lnx86/lib/vnclibs/libstdc++.so.5
    /home/install/EXT181/tools.lnx86/lib/vnclibs/libstdc++.so.5
    /home/install/ASSURA41/tools.lnx86/lib/vnclibs/libstdc++.so.5
    Please let me know , how can i figure out this issue now?
    You've installed the 64-bit RPM - you need the 32-bit RPM as cdsXvnc is a 32-bit executable.
    However, you can probably workaround it by doing:
    setenv LD_LIBRARY_PATH $CDSHOME/tools/lib/vnclibs:$LD_LIBRARY_PATH
    (you might not have $CDSHOME set - this is a placeholder for your IC installation). I've also assumed csh - you might need equivalent export statement for bash/ksh or other Bourne-like shells.
  • rtyuy
    Andrew Beckett , dear can you please explain it more , where can i "setenv LD_LIBRARY_PATH $CDSHOME/tools/lib/vnclibs:$LD_LIBRARY_PATH" do this statement.
    and also how to go for it
    In the terminal before you start Virtuoso (where you are trying to run cdsXvnc) either type:
    setenv LD_LIBRARY_PATH /home/install/IC617/tools.lnx86/lib/vnclibs:$LD_LIBRARY_PATH
    or:
    export LD_LIBRARY_PATH=/home/install/IC617/tools.lnx86/lib/vnclibs:$LD_LIBRARY_PATH
    depending on which shell you're using. If it complains about LD_LIBRARY_PATH not being defined, try the command with the part from the colon (:) onwards missing (e.g. setenv LD_LIBRARY_PATH /home/install/IC617/tools.lnx86/lib/vnclibs )
    Then in the same terminal, run cdsXvnc (and if that works - it will probably complain about the display not being set), then try "virtuoso -nograph" and see whether that starts (you'll need to type exit() to quit that).
    Ultimately you'd put the setenv/export in whatever startup script you use to set up your environment.
  • rtyuy
    Andrew Beckett
    [user@eeiitj123 ~]$ setenv LD_LIBRARY_PATH /home/install/IC617/tools.lnx86/lib/vnclibs:$LD_LIBRARY_PATH
    LD_LIBRARY_PATH: Undefined variable.
    [user@eeiitj123 ~]$ export LD_LIBRARY_PATH=/home/install/IC617/tools.lnx86/lib/vnclibs:$LD_LIBRARY_PATH
    [user@eeiitj123 ~]$ cd parm_65phd/
    [user@eeiitj123 ~/parm_65phd]$ csh
    [user@eeiitj123 ~/parm_65phd]$ source /home/install/cshrc
    [user@eeiitj123 ~/parm_65phd]$ cdsXvnc
    still the error occurs!
    My guess is that the /home/install/cshrc is resetting LD_LIBRARY_PATH - so perhaps you should set it after sourcing that file.
    Note, the right thing is to install the 32-bit compat package, but this may give you a workaround. Also, the really right thing is not to be using such an old and unsupported version of Virtuoso...
