  3. Unable to run Monte-Carlo simulation on ADE-XL
  • Replies 32
  • Subscribers 136
  • Views 12449
rtyuy
rtyuy over 1 year ago
Dear Friends,
I am using cadence virtuoso  (SUB VERSION: IC6.1.7-64b.500.19 (64-bit addresses)). Earlier Monte Carlo was running fine. but now when i run MC on ADEXL, it is showing following  error :
ADEXL-1921: failed to start new job after 3 attempts . Possible reasons could be
1. The machine selected in the current job set up policy is not reachable
2. The cadence hierarchy is not detected, not installed properly, or not compatible on the machine selected in the current job set up policy.
3. Job start script /home/vlsi2/laxman/.temp_vlsi2/.cmddir0/runICRP17 is not found in the remote machine.
          Do you want to retry with the current set up? Selecting no will abort the current session.
Please  help me in finding the solution  of this problem.
i have  also  tried to change the license but it is still not working.
    Andrew Beckett over 1 year ago +1
    I merged your posts (please read the forum guidelines - the pinned post at the top of each forum - as this tells you not to post duplicate posts in different forums; this will increase the chance of your…
  • rtyuy
    rtyuy over 1 year ago in reply to Andrew Beckett
    Andrew Beckett if do source /home/install/cshrc
    i move to
    Welcome to Cadence Tools Suite
    [user@eeiitj123 ~/parm_65phd]$ export LD_LIBRARY_PATH=/home/install/IC617/tools.lnx86/lib/vnclibs:$LD_LIBRARY_PATH
    export: Command not found.
    (I understand that i am using older version but i have no  other option as i told earlier  :(  )
    Andrew Beckett over 1 year ago in reply to rtyuy
    Since you were starting csh earlier, you will need to use the "setenv" approach instead. export is for bash/ksh type shells.
  • rtyuy
     Andrew Beckett ,  i have done
    [user@eeiitj123 ~/parm_65phd]$ setenv LD_LIBRARY_PATH /home/install/IC617/tools.lnx86/lib/vnclibs:$LD_LIBRARY_PATH
    user@eeiitj123 ~/parm_65phd]$ cdsXvnc
    Couldn't open RGB_DB '/usr/X11R6/lib/X11/rgb'
    23/07/25 02:55:27 Xvnc version 3.3.7 - built May 31 2004 15:31:52
    23/07/25 02:55:27 Copyright (C) 2002-2003 RealVNC Ltd.
    23/07/25 02:55:27 Copyright (C) 1994-2000 AT&T Laboratories Cambridge.
    23/07/25 02:55:27 All Rights Reserved.
    23/07/25 02:55:27 See http://www.realvnc.com for information on VNC
    23/07/25 02:55:27 Desktop name 'x11' (:0)
    23/07/25 02:55:27 Protocol version supported 3.3
    23/07/25 02:55:27 Listening for VNC connections on TCP port 5900
    Fatal server error:
    Couldn't add screen
    That's expected - as I said earlier:
    Andrew Beckett said:
    Then in the same terminal, run cdsXvnc (and if that works - it will probably complain about the display not being set), then try "virtuoso -nograph" and see whether that starts (you'll need to type exit() to quit that).
    Hopefully if that is all successful, then you'll be able to run simulations in ADE XL or Assembler.
  • rtyuy
     Andrew Beckett  again same problem
    [user@eeiitj123 ~/parm_65phd]$ virtuoso -nograph
    2025/07/23 12:15:13 WARNING This OS does not appear to be a Cadence supported Linux configuration.
    2025/07/23 12:15:13 For more info, please run CheckSysConf in <cdsRoot/tools.lnx86/bin/checkSysConf <productId>
    *WARNING* Unable to open -nograph X Window Display "eeiitj123.iitj.ac.in:80"
    *WARNING* (using "exec /home/install/IC617/tools.lnx86/dfII/../bin/cdsVncserver :80 -co /usr/share/X11/rgb&").
    *WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/eeiitj123.iitj.ac.in:80.log
    Trying another display...
    *WARNING* Unable to open -nograph X Window Display "eeiitj123.iitj.ac.in:81"
    *WARNING* (using "exec /home/install/IC617/tools.lnx86/dfII/../bin/cdsVncserver :81 -co /usr/share/X11/rgb&").
    *WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/eeiitj123.iitj.ac.in:81.log
    Since it is telling you that there's a problem and it created a log file, can you share the log file?
  • rtyuy
    it is written as :
    2025/07/23 12:16:11 WARNING This OS does not appear to be a Cadence supported Linux configuration.
    2025/07/23 12:16:11 For more info, please run CheckSysConf in <cdsRoot/tools.lnx86/bin/checkSysConf <productId>
    23/07/25 12:16:11 Xvnc version 3.3.7 - built May 31 2004 15:31:52
    23/07/25 12:16:11 Copyright (C) 2002-2003 RealVNC Ltd.
    23/07/25 12:16:11 Copyright (C) 1994-2000 AT&T Laboratories Cambridge.
    23/07/25 12:16:11 All Rights Reserved.
    23/07/25 12:16:11 See http://www.realvnc.com for information on VNC
    23/07/25 12:16:11 Desktop name 'eeiitj123.iitj.ac.in:81 (parminder)' (eeiitj123.iitj.ac.in:81)
    23/07/25 12:16:11 Protocol version supported 3.3
    23/07/25 12:16:11 Listening for VNC connections on TCP port 5981
    Font directory '/usr/share/X11/fonts/' not found - ignoring
  • rtyuy
    it is written as
    23/07/25 12:15:17 Desktop name 'eeiitj123.iitj.ac.in:80 (parminder)' (eeiitj123.iitj.ac.in:80)
    23/07/25 12:15:17 Protocol version supported 3.3
    23/07/25 12:15:17 Listening for VNC connections on TCP port 5980
    But when i checked the font tried to install  xorg-x11-fonts-75dpi xorg-x11-fonts-100dpi xorg-x11-fonts-misc, following output is achieved
    Package xorg-x11-fonts-75dpi-7.5-9.el7.noarch already installed and latest version
    Package xorg-x11-fonts-100dpi-7.5-9.el7.noarch already installed and latest version
    Package xorg-x11-fonts-misc-7.5-9.el7.noarch already installed and latest version
    Can you try this:
    df -kT /usr/share
    ls -li /usr/share/X11/fonts/
    I'm particularly interested in the inode number - there's a possibility (we've seen this elsewhere) that it's using large inode numbers, higher than can be read with a 32-bit executable. If it's this, there's little that can be done other than moving to IC6.1.8 (recent ISR).
    At this stage I'm clutching at straws - and I cannot realistically spend more time trying to debug (over the forums) an issue with an unsupported release when the solution is to move to a newer version.
    See also this article (check the directories to see what is installed).
  • rtyuy
    i  am sorry that it is stretching too much
    Filesystem              Type 1K-blocks     Used Available Use% Mounted on
    /dev/mapper/centos-root xfs   52403200 25357820  27045380  49% /
    [root@eeiitj123 parm_65phd]# ls -li /usr/share/X11/fonts/
    total 172
      2279051 drwxr-xr-x. 2 root root 49152 Dec  2  2020 100dpi
      2562112 drwxr-xr-x. 2 root root 49152 Dec  2  2020 75dpi
    2564556 drwxr-xr-x. 2 root root 4096 Dec 2 2020 cyrillic
    894141 drwxr-xr-x. 3 root root 4096 Dec 2 2020 encodings
    36235297 drwxr-xr-x. 2 root root 12288 Dec 2 2020 misc
    i have also installed 32 bit compat package now
