  3. Follow Up Discussion on Maestro can't save current with...
  • Subscribers 136
  • Views 675
Follow Up Discussion on Maestro can't save current with "WARNING (ADE-1063): The output with same signal '***' is already defined."
Kelsey Reed
Kelsey Reed over 1 year ago
I am currently having the same issue as the original poster on Maestro can't save current with "WARNING (ADE-1063): The output with same signal '***' is already defined." - Custom IC Design - Cadence Technology Forums - Cadence Community (as I'm sure many of the community are) so it would be great if we could get the solution posted to this discussion so that it comes up when people search.
What was the solution/workaround for this issue??
Thanks so much in advance!
  • Kelsey Reed
    I'm using Virtuoso Studio IC23.1.
