  3. quantus parasitic extraction vs. SKY130 PDK
  • Subscribers 137
  • Views 4953
GS202507021424
GS202507021424 over 1 year ago
I'm using `sky130_release_0.1.0` downloaded from Cadence, and I'm trying to do parasitic extraction on the layout of an inverter I've cut'n'pasted from `sky130_scl_9T`.
I've succeeded in running Pegasus -> DRC, then Pegasus -> LVS (where I was careful to enable "Create Quantus Input Data" on the "output" screen).
Next, I'm trying to run Quantus -> Pegasus, and I'm having trouble specifying the "quantus technology file". When I try to add ` /opt/cadence/pdks/SKY130/sky130_release_0.1.0/quantus/extraction/typical/qrcTechFile` to the "Quantus Tech Lib" field, it eventually complains that it's "not a valid technology file":
https://imgur.com/a/g3YIhmR (for some reason embedding the image in this post didn't work for me)
When I try running Quantus without specifying the technology file, I eventually get an error that quantus "could not find a valid Quantus tech file (e.g., qrcTechfile, cap_coeff.dat)" (also visible via the above link).
Has anyone successfully done a Quantus parasitic extraction using the Cadence version of the SKY130 pdk ?
--Gabriel
  • RK202509013321
    RK202509013321 over 1 year ago
    Did you find any resolution to this?
    Andrew Beckett over 1 year ago in reply to RK202509013321
    See my response to your other post (I didn't see this one at the time Gabriel posted it). That should answer Gabriel's question too, I think.
    I can see from the screenshot that Gabriel specified the qrcTechFile in this field rather than a pvtech.lib type file.
