  3. ERROR (NVN-13010): Cell rupolym is not defined while running...
  • Subscribers 136
  • Views 2921
ERROR (NVN-13010): Cell rupolym is not defined while running Pegasus LVS
yogeshjaiswalCAD
yogeshjaiswalCAD over 1 year ago
Greetings Team,
Thanks for always being there for help. I am facing ERROR (NVN-13010): Cell rupolym is not defined while running Pegasus LVS for OA database.
I have shared si.log for your reference.
[LVS] Ivs X
Pegasus 24.10-64b Reports: Failed [LVS] lv...
Jhed loading cdl netlist /home/yogesh/proj/TestChip/1vs/svdb/ref_stgl_pinput.net (0s) commit cdl netlist (s)...
ERROR (NVN-13010): Cell rupolym is not defined.
Please suggest to me what option needs to be checked or selected in the Pegasus LVS option tab.
I will be grateful for your help. Please help in !
Yogesh Jaiswal
    First of all, please read the forum guidelines (these ask you not to post the same question in more than one forum).
    Please look at this article: ERROR (NVN-13010): Cell XXX is not defined which explains why this is failing (I'm assuming rupolym is a primitive devices in the technology you're using).
  • yogeshjaiswalCAD
    yogeshjaiswalCAD over 1 year ago in reply to Andrew Beckett
    Greetings Andrew,
    Thanks for your reply.
    trust me, It means a lot when you take time from your busy schedule to reply to such answers no one can imagine :)
    Could you please share your solution on this post (a screenshot will help) for better understanding ?
    Any solution will help, whether that be adding options in Cadence Pegasus LVS options or adding a PVL file.
    Regards & Cheers,
    Yogesh Jaiswal
    Andrew Beckett over 1 year ago in reply to yogeshjaiswalCAD
    Yogesh,
    I already posted a link to an article which describes in detail various scenarios for this error, how it is often set up for common PDKs and screenshots of the UI if needed.
    Having a link makes more sense as then if the requirements change in different versions, that article will get updated. So I won’t post the (lengthy) contents of the article here too.
