  3. Cannot obtain the license for spectreRF when interfacing...
  • Replies 17
  • Subscribers 136
  • Views 7001
Cannot obtain the license for spectreRF when interfacing matlab with spectre
SW202509035411
SW202509035411 over 1 year ago
Dear all,
I am current trying to read spectre simulation results into MATLAB using the Spectre/RF MATLAB toolbox, but I got the error message when using cds_srr function in MATLAB:
Error: License for the SpectreRF option could not be obtained.
I refered to the procedure in SpectreRF Simulation Option Theory, and I also checked according to the posts:
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/34820/not-able-to-interface-spectre-data-with-matlab
https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/41322/cds_srr-doesn-t/1359466?focus=true
I checked the license (by echo $LM_LICENSE_FILE) and it is pointed to two license servers (The $CDS_LIC_FILE is undefined).
Also, before launching MATLAB (from the shell window of virtuoso), I set the dynamic library path by
setenv LD_LIBRARY_PATH `cds_root spectre`/tools/dfII:`cds_root spectre`/tools/lib:${LD_LIBRARY_PATH}
(In the manual, it should be setenv LD_LIBRARY_PATH `cds_root spectre`/tools/dfII/lib:`cds_root spectre`/tools/lib:${LD_LIBRARY_PATH}. However, I did not find the lib directory under dfII, so I changed the path to dfII.)
Besides, the MATLABPATH was also set to include the `cds_root spectre`/tools/spectre/matlab.
Versions:
MMSIM: MMSIM131_186
MATLAB: 2016a
Thanks a lot in advance!
Best Regards,
Sai
    Andrew Beckett over 1 year ago in reply to SW202509035411 +1
    Sai, I can't test this, but perhaps try: setenv LD_PRELOAD /export/releases/SPECTRE231_isr/tools.lnx86/lib/64bit/libstdc++.so.6 (note the path to your SPECTRE231 installation will be yours; this…
    The error message is actually wrong - it's not been updated since the license change happened. Using Spectre 23.1 with Matlab R2022b and playing with my available licenses, I see that it is checking (in…
  • SW202509035411
    SW202509035411 over 1 year ago in reply to Andrew Beckett
    Thank you for your suggestions! I checked the licenses you provided, but none of them are available. Here is what I did
    module load cadence/spectre/231_802
    /NAS/cad/cadence/SPECTRE231_802/bin/perf_test -f Virtuoso_Spectre -test_cp -lc 1
    /NAS/cad/cadence/SPECTRE231_802/bin/perf_test -f Virtuoso_Acceler_Parallel_sc -test_cp -lc 1
    /NAS/cad/cadence/SPECTRE231_802/bin/perf_test -f Virtuoso_Multi_mode_Simulation -test_cp -lc 1
    And the returns are the same:
    --- Checkout Performance Test A ---
    Description: Loop of checkout calls checking out the same feature with
                 additional ( upgrade ) license each iteration of the loop.
                 The server maintains one job with number of licenses over
                 the course of this test. The first license server will be
                 used if there are more than one server specified in the
                 license path.
    ERROR: CDS_LIC_FILE is not set.
           Please set CDS_LIC_FILE to point to a single license server
           or a triad redundant license server.
                          --- Checkout Performance Test B ---
                 additional ( incremental ) license each iteration of the
                 loop. The server maintains the number of jobs with one
                 license each over the course of this test. The first license
                 server will be used if there are more than one server
                 specified in the license path.
                          --- Checkout Performance Test C ---
    Description: Loop of checkout and checkin calls each iteration of the loop.
                 The server maintains one job with one license over the course
                 of this test. The first license server will be used if there
                 are more than one server specified in the license path.
                          --- Checkout Performance Test D ---
    Description: Loop of checkout calls each iteration of the loop.
                 License will be checked out from any of the available
                 license server specified in the license path.
    I also echo $CDS_LIC_ONLY, and it is undefined:
    CDS_LIC_ONLY: Undefined variable.
    However, $LM_LICENSE_FILE is set properly. It confused me that, although the three licenses are not avaible, there is no "License for the SpectreRF option could not be obtained" as long as I do not set the LD_PRELOAD. When I set the LD_PRELOAD, the license cannot be obtained.
    Or, is there any possibility to use a older version of spectre, e.g., spectre 17.1, so that to fit the matlab2016? I tried this, but the error message are the same -- it cannot obtain the license.
    Thanks again for your patient help!
    Best Regards,
    Sai
  • SW202509035411
    Thank your for your suggestions! I checked the three licenses but none of them are available. I also checked $CDS_LIC_ONLY, it is undefined. However, the LM_LICENSE_FILE is set properly. What confused me is that, although the three licenses are not available, there is not "License for the spectreRF option could not be obtained" message as long as I do not set the LD_PRELOAD. If I set the LD_PRELOAD, the license cannot be obtained.. (I wrote a reply containing the detailed error messages, but I was informed that the reply is determined to be SPAM... Maybe the reply is too long. Sorry for that.)
    Or, is there any possibility to use an older version of spectre, e.g., spectre 17.1, so that to fit the Matlab 2016? I tried this, but the problem is the same -- it cannot obtain the license.
    Best Regards,
    Sai
    Sai,
    If none of the licenses are available via the perf_test, it's never going to work (with this or the older version of Spectre).
    That's not surprising. If you are getting the issue with the Invalid MEX-file message then the MEX file won't be loaded, and since it's not loaded it can't try to do the license checkout and then fail. In other words, the code that is doing the license check is never called. Using the LD_PRELOAD allows a compatible version of the libstdc++.so.6 to be loaded both by Matlab and by the MEX file for the Spectre toolbox, and hence it gets to doing the license check.
    I found that post awaiting appeal and approved it, so I can now see the detail. It went into moderation because of the repeated text, most likely.
    Unsurprising, because the problem is licensing, not the version you're using.
    Please set CDS_LIC_ONLY (the perf_test seems to require that env var to be set - it doesn't use LM_LICENSE_FILE), and repeat the perf_test. I'm not sure I understand the reluctance to set that specific env var (we generally recommend setting the Cadence-specific env variable rather than the generic LM_LICENSE_FILE, as particularly with CDS_LIC_ONLY, this leads to better license performance as you don't end up checking irrelevant license servers).
  • SW202509035411
    Thank you so much for your reply! I have learned quite a lot from your instructions! I set the CDS_LIC_ONLY and CDS_LIC_FILE as follows:
    setenv CDS_LIC_FILE 5280@licsrv02
    setenv CFS_LIC_ONLY 1
    And I repeat the perf_test, it gave me a very long message containing Test A, Test B, Test C and Test D. The error message are the same:
    ERROR (LMF-03010): License call failed for feature Virtuoso_Spectre, version 1.000 and quantity 1. The license server search path is defined as 5280@licsrv02. The FLEXnet error message is as follows,
        FLEXnet ERROR(-10, 0, 0): Feature has expired.
    Run 'lic_error LMF-03010' for more information.
    So I ran lic_error LMF-03010, and got
    ERROR (LMF-02010): Feature has expired.
    The feature has expired. Today's date is after the expiration date in the
    license file.
    Contact Cadence support at support@cadence.com for further assistance.
    I also read your post in https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/21033/cadence-ic-6-14-license-issue, so I tried lmstat -a -c 5280@licsrv02, it returns a large amount of information containing the location of the license file, the feature usage info, etc., so I guess there is nothing wrong for the communication with the license server.
    Thanks again for your patience!
    Best Regards,
    Sai
  • SW202509035411
    Thank you for your reply! Could you please approve the post? It was blocked again.. I tried to set the CDS_LIC_ONLY and CDS_LIC_FILE, and repeat perf_test. It returned an error message (LMF-03010, I am afraid this reply can be blocked again if I post the entire message, sorry for that..). I also ran lmstat -a -c 5280@licserverhostname according to your post in https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/21033/cadence-ic-6-14-license-issue, and I thought the communication with the license server works well.
    Thanks!
    Best Regards,
    Sai
    If a post gets blocked, please appeal it rather than keep posting again and again (I don't generally go and check posts awaiting appeal because then I have to wade through all the real spam posts).
    Anyway, I found it (at least one of them) and approved.
    The error message is clear:
    it's telling you that you are past the expiration date in the license file (for this feature, at least). The lmstat will still list expired licenses (I think), so you should look at the license file itself.
    If you're getting the expired feature error for all the three licenses, that's your problem...
  • SW202509035411
    Got it! I will appeal next time. Sorry to bother you..
    I see.. I will contact our lab's support to check the license then...
    Thanks a lot!
    Best Regards,
    Sai
