  3. Copy schematic/symbol views hierarchically
  • Subscribers 136
  • Views 1054
ycau
ycau over 1 year ago
I try to use this feature to copy schematic/symbol views of cells across multiple libraries into one single library. The single library is a new library, created with tech lib attached.
I also created the top cell in the new library.  Then I went to the previous library where the top cell is and selected its schematic view to copy.
After following the steps from the copy help, I ran into the "Copy Problems" dialog.
There are conflicts errors. I selected "Copy Anyway" for all such cells.
Then I click "OK". After that nothing happens.
By the way, I tried to insert pictures here, but always got error: "An error occurred. Please try again or contact your administrator".
  • ycau
    The virtuoso version is
    ICADVM20.1-64b.500.31
    Andrew Beckett over 1 year ago in reply to ycau
    Please contact customer support (submit a case via the case menu after logging in). It's going to be very hard to diagnose this without seeing it.
