  3. I am encountering an issue where EMX cannot read or display...
  • Subscribers 136
  • Views 4047
I am encountering an issue where EMX cannot read or display Metal 8 and Metal 9 layers in the layout view. Metal 6 appears correctly.
SA202511121933
SA202511121933 over 1 year ago
I am encountering an issue where EMX cannot read or display Metal 8 and Metal 9 layers in the layout view. Only Metal 6 appears correctly.
Reproduction Steps & Observations:
  • I am attempting to simulate an inductor designed on Metal 8. When generating the EMX view, Metal 8 is missing entirely from the layout (see attached screenshot: With_Metal8.png).
To isolate the issue, I changed the inductor from Metal 8 to Metal 6. After this change, EMX correctly recognizes and displays Metal 6, and the simulation produces expected results (see attached screenshot: With_Metal6_.png).
I am using following software versions.
  • Tool: EMX (version: 6.2)
  • PDK/Technology: TSMC 65nm
  • Cadence Virtuoso version: IC6.1.8-64b.500.21
This is my first time working with EMX so I have no idea what where I am going wrong.
    It appears that you're using the generic65.proc sample proc file that comes with EMX rather than a specific one for TSMC n65.  You need to ensure that you have this proc file for the metal stack that you're using and that you set up the emxconfig.il file to point at it (and the layer map for the technology you're using - usually in the technology library. It appears that the layer numbers and datatype numbers in the generic65.proc broadly match TSMC layer numbers but not exactly (I see M8/metal8 is different for example). Even so, the process information is not going to be accurate if using the generic65 - it won't be the real layer thicknesses and dielectric thicknesses, etc.
    The usual approach is to get the IRCX file from TSMC (which they use to store all their technology data such as layer thicknesses and dielectric information etc), and then request a parser from Cadence (contact your account team or submit a support case by logging in to http://ask.cadence.com and then using the Case menu to submit a case) - this parser can produce a proc file from the IRCX file.
    You're also using an old version of EMX (that's not likely to be the reason though).
  • SA202511121933
    SA202511121933 11 months ago in reply to Andrew Beckett
    Thank you for replying. I have contacted cadence and they have sent me a parser. But where can I find the IRCX file. I can see a .rcx file in calibre folder but other than that I am unable to find anything. Also once I find IRCX file how do I produce a proc file.
    Andrew Beckett 11 months ago in reply to SA202511121933
    To get the IRCX file you should contact TSMC or your distributor, but this should be available in the Quantus setup for the metal stack you're using (it may not be in the PDK).
    To run the parser (and the support/account team should tell you this), you need to be in the directory containing the ICRX files, and then simply run the runparser_65nm.sh script (no need for any arguments - it looks for all *.ircx files in the working directory).
