  3. Find and replace variable names (and names in general) in...
  • Subscribers 137
  • Views 2344
Find and replace variable names (and names in general) in ADE Assembler expressions
NL202409233636
NL202409233636 11 months ago
Hello everyone!
Is there an easy way to find and replace all the occurrence of a design variable/global variable name in all my ADE Assembler expressions (written under the Details column)?
As an example, let's imagine I start working on a testbench using the global variable Resistor. I'll create all my expressions with VAR("Resistor"). Then I find a name that suits much better, like Rs.
Is there a way to easily replace all VAR("Resistor") with VAR("Rs") in the ADE Assembler UI?
Thank you!
    Andrew Beckett 11 months ago in reply to Kevin T Buck +1
    I didn't see the original post (there's been an issue with occasional missing notifications on the forums). The easiest way of doing this is to save the expressions to a file (there's a save icon at…
  • Kevin T Buck
    Kevin T Buck 11 months ago
    I'm not aware of a way to do this. You could try doing a search and replace in the maestro.sdb text file although I've never actually tried this myself.
    The easiest way of doing this is to save the expressions to a file (there's a save icon at the top of the Outputs Setup tab), edit the file, and then use the icon to the left of it to load it back in again. In IC25.1 ISR3 there will be an icon to do this in one step - it will save, launch an editor, and then re-load when the editor exits.
    You can also Export/Import variables to CSV (use the right mouse button menu over the Global Variables or Design Variables) to edit variable names.
  • NL202409233636
    NL202409233636 11 months ago in reply to Andrew Beckett
    Thanks!
