  3. problem extracting the Cc netlist from Quantus
  • Subscribers 129
  • Views 49
yogeshjaiswalCAD
yogeshjaiswalCAD 5 hours ago
Greetings Team,
Please help me to debug Quantus si.env issue
I performed LVS using following file:
1. Pegasus LVS (GDS + Verilog)
2. LVS clean
I am facing a problem extracting the Cc netlist from Quantus, as the following error message is appearing:
ERROR (LBRCXM-756): For extracted view output with transfer property function enabled by extview.trp file, ?cdloutRunDir '/home/jayashankar/proj/TestChip_tsmcN22/lvs_adc_curr_cdl' (or 'output_db -cdl_out_map_directory <name>') must contain file 'si.env', along with directories 'map' and 'ihnl'.
ERROR (LBRCXM-709): ***** Quantus terminated abnormally *****
Please help to fix this issue. I wanted to generate Cc exraction from LVS folder where i did  Pegasus LVS  clean using GDS + Verilog.
Thanks for your support & help!
Best regards,
Yogesh Jaiswal
    Andrew Beckett 4 hours ago
    Yogesh,
    See:
    • How to run Quantus with Extracted View or Smart View output when schematic or cdlout dir is not available
    • extview.trp file is missing and similar error messages listed below
    For extracted view generation, CDL netlist is really required, rather than using a Verilog netlist.
