  3. Issue with Missing Layout in TSMC 65nm PDK
  • Subscribers 137
  • Views 5040
DY202601279011
DY202601279011 9 months ago
Hi everyone,
I'm currently workingon a chip design using the TSMC 65nm PDK. However,I encountered an issue where MOSFET layout instances (e.g., nch/pch) appear only as boxes with an “X” instead of generating the actual layout.The following warnings are reported in the CIW: *WARNING* (DB-220706): The Pcell plug-in for super master 'tsmcN65/pch/layout' could not be loaded: Cannot find IPcell 'cnDloPcell': Pcell evaluator 'cnDloPcell' not found: Plug-in Registration File Not Found: Plug-in file /opt/eda/cadence/IC618/share/oa/data/plugins/cnDloPcell.plg... *WARNING* (DB-220704): The Pcell super master 'tsmcN65/pch/layout' is not a SKILL super master. The usage of non-SKILL Pcells in Virtuoso is not a supported feature.
Interestingly, other devices in the same PDK, such as BJTs, can generate layout correctly. In addition, if I directly open the MOSFET layout view inside the PDK library, the layout can be displayed without errors. The issue only occurs when instantiating MOS devices in a user design.
I'd greatly appreciate any suggestions on how to resolve this issue. Thank you very much for your time!
    Andrew Beckett 9 months ago
    It sounds as if you're using the version of the PDK using non-SKILL PCells (PyCells) and that the plugin has not been configured or is not running correctly. This is a flow we (as Cadence) do not support, and the recommendation would be to use the version of the PDK which uses SKILL PCells. I can't answer with details because it almost certainly depends on the specific 65nm technology you're using, but getting the SKILL PCell-based PDK is the right way to do this.
  • DY202601279011
    DY202601279011 9 months ago in reply to Andrew Beckett
    Thank you very much for the clarification. That makes sense.
    In my case, I am working in an academic environment and unfortunately do not have direct access to alternative versions of the TSMC 65nm PDK (e.g., a SKILL PCell–based release). I was wondering whether there are any known Virtuoso versions or patch levels that are known to work more reliably with the non-SKILL (PyCell-based) 65nm PDKs, as this PDK is actively used by a collaborating research group in our institute.
    In other words, would reinstalling or switching to a different supported Virtuoso release (for example, an older IC6.1.x build) be a reasonable workaround in such cases, or is the SKILL PCell–based PDK strictly required regardless of the tool version?
    Any guidance you can share would be greatly appreciated.
    Best regards.
    Andrew Beckett 9 months ago in reply to DY202601279011
    As I said, Cadence does not support non-SKILL PCells, so we can't really provide any advice on how to use them. However, it may just be that the PDK has not been configured correctly and so the plugin can't be found because of that. There should be instructions with the PDK telling you how to do this. Or it might be that the plugin shared library is incompatible with the operating system or IC version you're using - you should check the PDK instructions for that.
    I'd be surprised that even in an academic environment that you can't access a current version of the PDK which is suitable for the tools you are using.
  • DY202601279011
    Thank you very much for your reply. The issue has now been resolved after I reinstalled the PDK. So it seems very likely that, as you suggested, something was not configured correctly during the previous PDK installation, which caused the plugin not to be found.
    Thank you again for your time and helpful comments, they were much appreciated.
    Best regards.
  • CM202602114545
    CM202602114545 9 months ago in reply to Andrew Beckett
    Hey Andrew
    we have no issue with PDK all the other library works normally its only with one library which was working fine till yesterday and has an issue now.We are able to generate new blocks which are fine just the saved layout has issue
    Andrew Beckett 9 months ago in reply to CM202602114545
    You seem to be somebody other than the person who started this thread, and if it's the same issue as the previously reported issue, then this makes no sense. Also, if it's related to a non-SKILL PCell plugin, I can't help as explained above.
    If it's a different issue, please start a new post with details as to what the actual problem is.
