  3. Very Basic Wire naming question
  • Views 1485
HL20260227511
HL20260227511 8 months ago
I am very new so please go easy on me. How do i name multiple wires with same name?(Like Vss, CLK) I tried to use "Attach to multiple wires" but it didnt work. I am trying to build strong-arm based latch
Thank you
Also, does Cadence forum usually not allow images to be uploaded?
    Andrew Beckett 8 months ago
    The "Attach to multiple wires" requires you to have have multiple names to attach. For example, if the input was "a b c d e" then without "Attach to multiple wires" you could click 5 times on different wires and the first would get a, second b etc. If you check "Attach to multiple wires" then after the first click you can move your cursor and a line is drawn, and any wire where the line intersects it will name that net.
    Or you could enter "<*5>Vss" in the Names field, clicl on "Expand bus names" and then each click would from a Vss (you have 5 Vss nets with this syntax), or you could use the Attach to multiple wires to drawn the line through five wires and get 5 Vss labels.
    Normally it does, but there's an intermittent problem which means that the image loading breaks sometimes (it seems to be for a period of time for specific users). We hope it will get fix when we upgrade to a newer version of the forum software from the vendor that supplies the forum system.
