  3. Wildcard '*' does not match any net in spectre save sta...
  • Subscribers 136
  • Views 1950
Wildcard '*' does not match any net in spectre save statement
msharma
msharma 8 months ago
My spectre netlist has this statement:
save IARRAY.* sigtype=all depth=1
IARRAY is an instance name.
However, when the transient simulation is run, no signals in the subcircuit instance IARRAY are saved. The simulator log has the following message:
Wildcard match summary:
               save IARRAY.* :         0
What could be the cause of the signals / nets not being saved?
    Andrew Beckett 8 months ago +1
    The depth is relative to the top of the design, so you need to specify depth=2 if you want to get any signals within the IARRAY instance. There was a similar question a while back which I answered here…
    Andrew Beckett 8 months ago in reply to msharma +1
    It should be fine to have sigtype=all *but maybe you're getting other things saved too - not sure. However, you should find if you scroll to the right on the save by subckt form, there's a column for…
    There was a similar question a while back which I answered here.
  • msharma
    msharma 8 months ago in reply to Andrew Beckett
    Thanks for the helpful info.
    On the topic of "sigtype", I used the "Outputs"->"Save All" in the Explorer to get the "Save Options" form.  The first column of outputs in "Save Bu Subckt" is titled V [depth]. I selected that column, and set the depth to 2. It created then etlist with the statement (simulation currently running):
    save MEMARRAY.* sigtype=all depth=2
    In your detailed answer to the similar question, you suggested to use sigtype=node. Since the "Save Options" form does not have an option for "Nodes", can I change it in my netlist and run the simulation from the command line?
    However, you should find if you scroll to the right on the save by subckt form, there's a column for sigtype. I'm running on a newer OS so I'm limited to (about) IC6.1.8 ISR24 as the earliest version I can go back to - this is about 4 years old - and it's certainly available there.
    No need to change in the netlist and run from the command line.
    Worst case, you could put the save statement into a file (saves.scs for example) and then include this via Setup->Simulation Files - in the Definition files (or as a model library).
  • msharma
    Thanks for the helpful information!
