  3. variable for number of iterated instances
  • Subscribers 136
  • Views 908
Volker T
Volker T 5 months ago
I am referring here to post "Can I use a variable for number of iterated instances".
There is now a solution to change the number of instances of an instance array using "Window -> Assistants -> Variables and Parameters. Click on component to iterate. Click on iterInstMultiplier parameter -> Create Parameter Range" in ADE.
This is a great feature, and I wonder if and how one can evaluate "iterInstMultiplier" of the affected instance array in an Output Expression.
Assume I have an array of parallel transistors and I would like to calculate the current through each individual transistor, then one way is to record total current by an iprobe and then divide by "iterInstMultiplier" ascurrently set by parameter.  (This is just a simple example, not the actual problem I am trying to scolve.)
But how to access the value of this parameter?
I found a rather complex work-around:
In CIW, i enter
openResults()
selectResults()
report()
and then I find the alias name "DPAR_1" that represents the parameter I am looking for. Then, using
pv("top-level" "DPAR_1" ?result "designParamVals")
I can finally access its value. However, if there is more than one such parameter, it starts getting complicated.
So, I guess there MUST be a much simpler way to do this directly?
    Andrew Beckett 5 months ago
    OK, you can do it like this.
    1. When you set the iterInstMultiplier, rather than directly setting a sweep of the parameter, set it to (say) ITERMULT
    2. Then define a global variable called ITERMULT to (say) 4:1:10 (sweeping the number of iterated instances indirectly via a variable)
    3. Then you can use VAR("ITERMULT") in your output expressions.
    I have a CCR (3085324) which is already asking for an equivalent of VAR for parameters (e.g. PARAM) but this has not been implemented yet; if that existed, then this intermediate step of using an indirect variable wouldn't be needed (although the PARAM syntax would be more complex as it would need to know lib, cell, view, inst and param name)
  • Volker T
    Volker T 5 months ago in reply to Andrew Beckett
    Thank you very much, Andrew.
    And yes, something like PARAM(), as an access function similar to VAR(), to get the parameter value used in a simulation run, is exactly what I was looking for. It's great to hear that there already is a CCR for this.
    Volker
