  3. Stacked Vias
  • Replies 17
  • Views 29352
Stacked Vias
Davadaroo Baba
Davadaroo Baba over 17 years ago
I am interested to know if these's a way to create a stacked VIA, say a stack of VIA4 & VIA5 in a 6 metal process.
I am interested to know  how do I add this Stack VIA in the technology file? Can I add it to the tech file throught an API like the CreateStdVia & the CreateCustomVia? Or should I specify it in a constarain group entry(desired one),
I need Via4 & VIA5 placed one over the other.
Thanks in Advance.
Krish
    Andrew Beckett over 17 years ago
    Which version are you using? The answer is different between IC5141 and IC613.
  • Davadaroo Baba
    Andrew,
    I am using 6.1.3
    Regards
    Hi Krish,
    In that case, you should use Create->Via and then select "Stack" and you can enter the start and stop layers. It will create a stack of vias. Yes, it's multiple via objects, each of which is between a pair of layers, but this has the advantage of being simpler, and also better understood by multiple tools.
    If  you use create wire, and change through multiple layers (e.g. hit the space bar to change layer), it will place a stack of vias for you.
    Also, in the "Options" toolbar there is an icon to control whether Via Stack selection is on or not (this also appears on the Options->Selection form). What this does is ensure that if you click on a stack of vias, it selects the entire stack, rather than just the individial vias.
    So there really is no need (and indeed it's not recommended) to create specific stacked vias in the tech file.
  • Davadaroo Baba
    This is the exact way I am following now.
    But I  am trying to  get  the following mechanism work :
    ( "Dummy_via_group"    nil
        interconnect(
         ( validLayers   (NW OD PO1 M1 M2 M3 M4 M6 .....  ) )
         ( validVias     ( M1__PO M2_M1 M3_M2 M4_M3 M5_M4 M6_M5 ))
        ) ;interconnect
    If I select the  following via group and create a wire,  when I move from M4 to up , it mus place  a stacked Via containing M5_M4_VIA & M6_M5_VIA
    What  changes do I do in the technology file if needed  to achieve this.
    You don't have M5 in the valid layers. If you have M5 in the valid layers, you can hop from M4 to M6 and it should put both vias in, as a stack.
  • Davadaroo Baba
     M5 in my case becomes an invalid routing layer and will be not available.
    There are 2 cases.
    #1. Process XYZ Where M1, M2, M3, M4, M5 & M6 are available and it puts up a stack, everything works great
    #2. Process ABC Where only M5 is absent and this is where I face the problem. Especially when I want to  have design portability between the 2 options.
    Krish,
    If M5 is absent in the process, don't you just need to define an M4_M6 via - it's not going to be stacked, because there's no M5? Or have I misunderstood? I can't see how you could have a stack from M4 to M5, then M5 to M6 if there's no M5 in the process...
  • Davadaroo Baba
     Yes M5 is absent in this process option .
    If I have M6_M4 Via I will face a major issue in porting this desigh to the process option where M5 is present. Because there we do not have a Via M6_M4 obviously.
    Any design using this M6_M4 via will not be portable in the process option with  M5 present.
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
    Setup a customViaDef which defines a via M6_M4 between M4 and M6.
     Create a pcell M6_M4 which draws the necessary layers for the via. It could check the valid layer list and not draw M5 or it could always draw V4, M5, V5 but the designer would not be able to route on M5 because it is not in the valid layer list. The pcell would have the parameters which coorespond to the stdViaDef parameters so the tools would place them correctly on wide wires.
    Create two  constraint groups, with and without M5 and use the appropriate one.
    ( "Design_With_M5_group"    nil
        interconnect(
         ( validLayers   (NW OD PO1 M1 M2 M3 M4 M5 M6 .....  ) )
        ) ;interconnect
    ( "Design_Without_M5_group"    nil
        interconnect(
         ( validVias     ( M1__PO M2_M1 M3_M2 M4_M3 M6_M4  ))
        ) ;interconnect
    When a designer finds the need for M5, they just switch constraint groups. The cell would still exist in the current library and would draw the appropriate layers.
  • Austin CAD Guy
    Message deleted.
