  3. SKILL profiler
  • Views 15804
SKILL profiler
tashah
tashah over 15 years ago
I want to use profiler to profile the time spent in each function. Basically, I am calling top-level function and it calls many other functions. I want to profile time spent in each of the functions.
 I started profiler, but before I press "stop" button, virtuoso was busy. You can not do anything, while your code is executing. If I don't press stop button then once function completes, the profiler window automatically shuts off.
Does anybody know how to use that profiler?
 Thanks.
    Normally you should hit the "start" button, run the code, and when finished, hit the "stop" button.
    If the profiler is being closed when your code finishes, my guess is that maybe your code has:
    hiCloseWindow(hiGetCurrentWindow())
    or similar inside - the profiler window may be the current window (quite likely if you just pressed the start button and then ran the function from the CIW), and hence it is that which is being closed by your code.
    This should not normally happen, so I expect it's a function of your code?
  • tashah
    Hi Andrew, thanks for quick response.
    My code doesn't have hiCloseWindow function. In a simple words, the code opens a cell, automate the layout process by calling other user defined functions, save the layout and returns. Is there anything I should change to enable profiling?
    Thanks.
    So am I correct in understanding that the profiler window is getting closed?
    If so, and there's nothing which is doing any kind of close window in your code, I think you will need to talk to customer support - who may need to see the problem. I've never come across this as a problem, so it's rather strange.
    Or if you can post some small code which shows this (together with the details of the version you're using) it would be good. And maybe the CDS.log showing the problem. But that would really be better going through customer support. Sorry about the sentences beginning with "And" and "But" there...
