  3. change library reference of all cells in a library
  • Views 23662
schee
schee over 15 years ago
How to change the libName of all cells in a libray?
Basically what I want is Library Manager's Edit->Rename Instances, where the "From Library" is any library. Apprarently putting * there doesn't do the job.
    The menu names you list don't match with what the library manager actually calls them, so maybe you have some customization in place? Anyway, normally you would just select the library you want to rename, and over the library name do Right Mouse->Rename.
  • schee
    Andrew, thanks for your response. Weird, the menu is indeed in my stock IC5141 installation. It's the 4th item on the Edit menu in Library Manager.
    I must have confused you with what I was trying to do. I don't want to rename a library, I want to rename the referenced library of all cells referenced in a same library. For example, my library A contains cell B, whose schematic instances cell C from another library D. I want to rename "D" to "A". Normally I would just use the aforementioned Library Manager manu to rename all instances "From Library D" "To Library A". But if there are many different outside library references, this has to be done for each one, which is a bit tedious. That's why I think a Skill script might be the solution.
  • skillUser
    skillUser over 15 years ago
    I think that you might want to take a look at Solution 11330942, the solution SKILL code defines a function CCSchangeReflib and another CCSchangeReflibEntireLib. I think that these might address your issue?
    Lawrence.
