  3. outfile for excel
  • Subscribers 150
  • Views 15601
outfile for excel
Aritra
Aritra over 15 years ago
HI, I am trying to write some information (eg pin names ) from both layout and schematic in an excel sheet. I am not able to write it in a separate column using outfile() and fprintf() command. Can any one help me with this? I am IC 5
  • skillUser
    skillUser over 15 years ago
    You can use a tab ("\t" within a printf output string) or a comma to create a tab-delimited or comma-separated (csv) format file that you can then read in directly with Excel. The tab or the comma would separate the columns, print the first line in the same format but with the column headings.
    Hope this helps.
    Lawrence.
  • Aritra
     Thanks skillUser,
                              The \t works perfect for me.
    I am facing another problem. Is there  Carriage return available as escape character in fprintf ? I tried using \r for doing the operation but it is not working.
    I need this for printing 3 diffrent columns side by side. So when I use \n new line for some time I need to go back to the initial position for printing the next set of data in the next column.I am unable to achieve this till now.
    Please assist.
