  3. How to get the minimum & maximum value of Device parameters...
  • Subscribers 152
  • Views 5835
How to get the minimum & maximum value of Device parameters ?
Amar Kumar
Amar Kumar over 11 years ago
I am writing a script to check the minimum & maximum value of the parameters of a device.
Ex:Consider a mos device.To get the minimum value of width of that particular mos i am doing as below.
cdfID = cdfGetInstCDF(mosID)
paramID_width = cdfFindParamByName(cdfID width)
minValue = paramID_width~>defValue
For most of the technology this value is equal to the minimum value,but for some it is failing.
Can you give a solution to get  minimum as well as maximum value of the parameter.
Amar Kumar
  • psill000
    psill000 over 11 years ago
    Not sure how your script is working or the process it flows.
    Some scripts I have used the functions min(a b) and max(a b) to something similar to what you want. You can look at the functions through the cdsFinder to get a better description.
    Paul
    Amar,
    Generally speaking, any minimum or maximum value of a parameter is checked by a CDF callback or similar - this is a bit of  SKILL code that runs when you change a parameter in a field. The limits may not be checked at all, or may be hardcoded into that function, or may be looked up from some properties stored somewhere.
    Put another way, there is no generic way to define what the minimum and maximum values of a parameter are, so you can't code a generic solution based on purely looking at the CDF parameters. Assuming that the default value is the minimum is definitely a wild assumption too!
  • Amar Kumar
    Thank you for clearing this doubt.
    Amar.
  • VadimBorisov
    VadimBorisov over 9 years ago
    delete
  • Mikexay
    Mikexay over 9 years ago
    Delete! sorry about that.
    Learn Vietnamese online( free for all cadence's members ):
    Lession 1: nho ninh thuận
