  3. Abut using Skill
  • Views 16434
Abut using Skill
Abhishek Iyer
Abhishek Iyer over 11 years ago
I have to generate a lot of test cases for MOS abutment.
So I have written a skill code to place mos devices with drain and source tied together in schematic (each schematic has 10 mos devices with varying widths in groups of 2 to test the abutment...  i.e. each schematic will test 5 abutment cases) and to create corresponding layout using lxGenFromSource.
Now I want to trigger abutment. Is there a way to do it using skill?
The abutment works perfectly using the UI mode. The abut function is  set up properly. Its just that I want to do the same through skill what I achieve through UI.
Regards
Abhishek
  • skillUser
    skillUser over 11 years ago
    Hi Abhishek,
    I don't think that there is a public SKILL API for specifically triggering abutment of cells, though in your case you might be able to use the VLS-XL Generate From Source ( lxGenFromSource() ) command with the ?initDoStacking option on for chaining devices together ?
    Hope it helps!
    Lawrence.
  • Abhishek Iyer
    This helped
    Thanks!!!!!
    The above solution may help.
    However, when doing some searching - I see you also logged a case with customer support. The forum guidelines ask you not to do that - asking customer support and posting in the forum tends to mean that more people are working on it than is necessary - and is less efficient.
    Sometimes we do ask you to contact customer support after posting in the forums - often for things that will take more time, or if there is a need to see your data which may not be possible in an open forum - but if you've already contacted customer support, it's best not to ask in the forums too...
