  3. a simulation problem...
  • Views 14917
Esmaeil
Esmaeil over 10 years ago
hi
in cadence i build a model(actually a npn transistor) but i can't simulate that...
it's nodes are not known in cadence...
i think that it should be defined to simulation.i mean  that i should make a simulation profile.
how can i do that?
    I have absolutely no idea what you're asking here. I've read it 5 or 6 times and cannot make out what on earth you're trying to do or what you have tried or what anything in your question actually means. I'd be amazed if anyone else can.
    Please read the forum guidelines. Gobbledegook questions are unlikely to get an answer!
  • Esmaeil
    my question is:
    how can i make a new model in cadence?plz explain each step...
    thanks
    Esmaeil Chehrehnama said:
    my question is:
    thanks
    I don't mean to be rude, but clearly you didn't bother reading the forum guidelines that I pointed you to.
    I should mention that there is no tool called "cadence". There's a company called Cadence (Design Systems) that is the provider of lots of different tools, none of which are called "Cadence". Given our portfolio, you could be talking about many things. Even if you were talking about a specific simulator, your question is ridiculously open-ended.
