  3. What is the difference between "hiCreate....Field" and ...
  • Views 2170
What is the difference between "hiCreate....Field" and "ahiCreate.....Field"?
fatcat1206
fatcat1206 over 10 years ago
Hi All
Does anyone know the difference between "hiCreate....Field" and "ahiCreate.....Field".
When I look at some codes for special functions provided by Andrew Beckett, I notice that "ahiCreate....Field" functions has been used for creating the form for the special function.
Unfortunately, I did not find any document for this function family.
I also look at all the defined functions in Virtuoso, it's almost one to one between "hiCreate.....Field" and "ahiCreate.....Field".
One thing I notice that, I only defined "string" type of field (code is shown below, follow the code from Andrew), but the content can convert to "integer" or "double" type automatically.
when the value of the field has been evaluated, and used to generate the string by calSpecialFunctionInput('func '(fControlWave fOperator fThreshold fOffValue))
Best Regards
Yi
procedure(SIScreateCalcWaveAndForm()
let((
    fControlWave
    fOffValue
    fOperator
    fThreshold
);local varialble
    fControlWave = ahiCreateStringField(
        ?name 'fControlWave
        ?prompt "Control Wave"
        ?value ""
    );ahiCreateStringField
    fOffValue = ahiCreateStringField(
        ?name 'fOffValue
        ?prompt "Off Value"
        ?value "0.0"
    fThreshold = ahiCreateStringField(
        ?name 'fThreshold
        ?prompt "Threshold"
        ?value ""
    fOperator = ahiCreateCyclicField(
        ?name 'fOperator
        ?prompt " "
        ?choices list("<" ">")
        ?value ">"
        ?defValue ">"
    );ahiCreateCyclicField
    calCreateSpecialFunctionsForm('SIScalcWavePassGateForm
        list(
            list(fControlWave   0:00    380:20      90)
            list(fThreshold     0:30    280:20      90)
            list(fOperator      350:32  30:20       1)
            list(fOffValue      0:60    380:20      90)
        );list
    ;printf("form is created\n")
);let
);proc
    Hi Yi,
    This use of the "ahi" functions is mostly historical - they were a special wrapper around the "hi" functions which ensured that the fields were tied to the ADE session appropriately. I haven't checked recently, but they may not be necessary any more - although given that the calCreateSpecialFunctionsForm uses them, they might be.
    Anyway, this is a moot point, because from IC617 there's a much better way of building the form - it ends up being fully integrated in the calculator rather than a separate popup form (it was possible in older releases, but it had some major disadvantages, which have been solved in IC617). See this recent blog:
    TeamADE
    Adding Weighted Noise Via Calculator Custom Function
    Applying a weighting factor to a Noise Summary run requires lots of steps and the results cannot be evaluated without using the form. Wouldn't it be much easier if you could have a calculator function…
    By TeamADE over 10 years ago in Cadence Blogs > Analog/Custom Design
  • fatcat1206
    HI Andrew
    Thank you for the reply.
    It will be really convenient for the new features in IC617. It save a lot of effort to make the form.
    Unfortunately, we are still using IC616, so I still have to make the form.
    I just do a simple test: replacing the "ahiCreate...Field" by "hiCreate...Field".
    Then the form fails to popup.
    So I still need "ahiCreate...Field".
    About the type conversion as mentioned in my post: "string" --> "double"
    I assume this part is taken care of by the "calSpecialFunctionInput()", is this right?
    Best Regards
    Yi
    Yes, I think so.
