  3. How to write the same function in IC 5.1 which dbGetHierPathTransform...
  • Views 15569
How to write the same function in IC 5.1 which dbGetHierPathTransform in IC 6.1 ?
Charley Chen
Charley Chen over 9 years ago
Hi All,
I want to copy lower hierarchy level of label to top level , I saw a source link
"SKILL script to copy lower level labels to the top level" ,
It can work in IC 6.1 ,But I need to do in IC 5.1 , IC 5.1  no dbGetHierPathTransform => undefined variable ...
How to let the code work in both IC 5.1 & IC 6.1 ?
Thank you,
Charley
    Hi Charley,
    See my code which I posted in response to this earlier post:
    varun kumar D
    How can I make this code to work in CDB database
    Hello, Following density code I have written for the cadence OA database but it is not working in CDB since the command is not available. Do we have any alternate of this dbGetHierPathTransform(overlap…
    By varun kumar D over 11 years ago in Cadence Technology Forums > Custom IC SKILL
    Latest by varun kumar D over 11 years ago
  • Charley Chen
    Thank you,I will study & try it.
    PS: How do I copy & paste the text to a new file will keep the same(has return line) ?
    Charley
  • Charley Chen
    I cnage the browser from Firefox to IE , It can do it.
    Charley
  • Charley Chen
    Hi Andrew ,
    Yes, It work. The function can do it.
    Thank you,
    Charley
