  3. Use for loop to create dynamic field in hiCreateAppForm
  • Replies 11
  • Views 22301
mantang
mantang over 6 years ago
Hi
I use for loop to generate same two fields 10 times, so I could change # of two fields easily in the future. Since nameHandle "symmetry1" and "group_instance" or symbol "'instances" and "'symmetry1" are same for two fields (10 times), how could I access the value of 20 fields (10 x 2 fields) in the form callback procedure ? Is it the correct approach ?
I could create 20 fields one by one using different symbol and nameHandle manually, but I don't think it is a good approach for code maintenance. Any suggestion ?
I saw an article about dynamic field https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/35948/accessing-dynamic-form-fields  , but I do not know how to use the code in hiCreateAppForm and nameHandle is the same for different symbol name of hiCreateRadioButton.
group_instance = hiCreateStringField(
?name 'instances
?prompt "Group instances"
symmetry1 = hiCreateRadioField(
?name 'symmetry1
?prompt "Device symmetry"
?choices list("Y" "N")
?value "Y"
?callback "symmetry1CB(hiGetCurrentForm())"
allList = nil
startx = 0
starty = 210
width = 600
height = 30
for(i 0 9
finalx = startx
finaly = 210 + (i*height)
finalx_f2 = finalx
finaly_f2 = finaly + height
flist = list(list(group_instance finalx:finaly width:height) list(symmetry1 finalx_f2:finaly_f2 width:height))
allList = append(allList, flist)
hiCreateAppForm(
?name 'ExampleForm
?formTitle "example form"
?callback 'ExampleFormCB
?fields allList
ManChak
    let((group_instance symmetry allList startx starty width height)
        allList = nil
        startx = 0
        starty = 210
        width = 600
        height = 30
        for(i 0 9
            ; use concat to give each field a unique name
                ?name concat('instances i)
            symmetry = hiCreateRadioField(
                ?name concat('symmetry i)
                ?value "Y"
            ; commented callback out for now as this needs to be a list
            ;    ?callback "symmetry1CB(hiGetCurrentForm())"
            finalx = startx
            ; add a *2 to stop the fields overlapping
            finaly = 210 + (i*height*2)
            finalx_f2 = finalx
            ; added prompt widths
            flist = list(
                list(group_instance finalx:finaly width:height 120)
                list(symmetry finalx_f2:finaly_f2 width:height 120)
            ; should really consider whether append is the right approach
            ; if there are many fields (lists are sequential). Maybe lconc or
            ; build list using cons and then reverse() at the end?
            allList = append(allList flist)
        hiCreateAppForm(
            ?name 'ExampleForm
            ?fields allList
  • mantang
    mantang over 6 years ago in reply to Andrew Beckett
    Thank you for your code. It clarifies my SKILL concept.  How do I pass a list of callback procedures in "?callback argument" inside for loop in this case since each radio field has its own callback procedure?
    ?callback list("symmetryCB(hiGetCurrentForm())")    ?
    ?value "Y"
    ManChak
    Andrew Beckett over 6 years ago in reply to mantang
    Hi ManChak,
    In this example, I use a common callback function, but pass in the field names to the callback so that the common callback can retrieve the associated fields. The other approach would be to construct the callback function name using sprintf in a similar fashion (so it could be symmetry%dCB for example).
    procedure(symmetryCB(form symmetry instances)
        printf("symmetry is %s\n" get(form symmetry)->value)
        printf("instances is %s\n" get(form instances)->value)
        allList = nil
        startx = 0
        starty = 210
        width = 600
        height = 30
        for(i 0 9
                ?value "Y"
                ?callback list(
                    sprintf(nil
                        "symmetryCB(hiGetCurrentForm() 'symmetry%d 'instances%d)"
                        i i
            finalx = startx
            finalx_f2 = finalx
            flist = list(
        hiCreateAppForm(
            ?name 'ExampleForm
            ?fields allList
  • mantang
    Thank you for your help. I will try the code.
    ManChak
  • mantang
    I use your code above to create "allList". I get syntax syntax if I use the following code for  hiCreateAppForm.
    I know item1 solution should work, but I prefer item2 solution if possible. I just want "allList" contains fields defined in the for loop.
    1) Do I need to add templateField, templateLoad, templateSave, sep1, libName to allList ?
    OR
    2) ?fields argument could accept multiple list ?
    hiCreateAppForm(
       ?name 'ExampleForm
       ?fields
       list(
          list(templateFile 0:0 600:30 200)
          list(templateLoad 100:5 45:20)
          list(templateSave 150:5 45:20)
          list(sep1 0:35 600:0)
          list(libName 0:40 600:30 200)
          allList
    *WARNING* promptWidth attribute must be a positive integer:
    *WARNING* ((stringStruct@0x2ed5fcb0 (0 210) (600 30) 120) (radioStruct@0x2ed5fcc8 (0 240) (600 30) 120) (stringStruct@0x2ed5fce0 (0 270) (600 30) 120) (radioStruct@0x2ed5fcf8 (0 300) (600 30) 120) (stringStruct@0x2ed5fd10 (0 330) (600 30) 120) (radioStruct@0x2ed5fd28 (0 360) (600 30) 120) (stringStruct@0x2ed5fd40 (0 390) (600 30) 120) (radioStruct@0x2ed5fd58 (0 420) (600 30) 120) (stringStruct@0x2ed5fd70 (0 450) (600 30) 120) (radioStruct@0x2ed5fd88 (0 480) (600 30) 120) (stringStruct@0x2ed5fda0 (0 510) (600 30) 120
    *Error* hiCreateAppForm: not all fields have 2D attributes specified,
    and/or illegal attribute values
    ManChak
    It fails because the list would be the wrong structure - you'd have the allList within the list with the other fields. You'd need to do (and I didn't test this because I don't have your other fields defined, but it should work):
    hiCreateAppForm(
       ?name 'ExampleForm
       ?fields
       append(
         list(
         allList
  • mantang
    1. Thank you for your help. It works,
    2. I have one question about your suggestion in the previous response. I tried lconc and cons in my code. According to SKILL manual, one argument of cons is item instead of list.
    Unlike append command,  "lconc" merges two lists together. How could I replace "append" command with either cons or lconc command to build allList ?
        x = tconc(nil 1) ; x is initialized ((1) 1)
    lconc(x '(2 3 4)) ; x is now ((1 2 3 4) 4)
    lconc(x nil) ; Nothing is added to x.
    lconc(x '(5)) ; x is now ((1 2 3 4 5) 5)
       x = car( x ) ; x is now (1 2 3 4 5)
    flist = list(
    ManChak
    ManChak,
    Here's the first version, using lconc:
            templateFile templateLoad templateSave sep1 libName)
        templateFile = hiCreateStringField(
            ?name 'templateFile
            ?prompt "Template File"
        templateLoad = hiCreateButton(
            ?name 'templateLoad
            ?buttonText "Load"
        templateSave = hiCreateButton(
            ?name 'templateSave
            ?buttonText "Save"
        sep1 = hiCreateSeparatorField(
            ?name 'sep1
        libName = hiCreateStringField(
            ?name 'libName
            ?prompt "Library Name"
        allList = nil
        startx = 0
        starty = 210
        width = 600
        height = 30
        for(i 0 9
                ?value "Y"
                ?callback list(
                    sprintf(nil
                        i i
            finalx = startx
            finalx_f2 = finalx
            flist = list(
    	; Example using lconc
    	; was using append here
            allList = lconc(allList flist)
        allList=car(allList)
        hiCreateAppForm(
            ?name 'ExampleForm
            ?fields
                append(
                    list(
                    allList
    Here's using cons and reverse:
            ?name 'templateFile
            ?name 'templateLoad
            ?buttonText "Load"
            ?name 'templateSave
            ?buttonText "Save"
            ?name 'sep1
            ?name 'libName
        allList = nil
        startx = 0
        starty = 210
        width = 600
        height = 30
        for(i 0 9
                ?value "Y"
                ?callback list(
                    sprintf(nil
                        i i
            finalx = startx
            finalx_f2 = finalx
    	; now using cons to construct the list - more efficient since
    	; it adds to the beginning
    	allList=cons(list(group_instance finalx:finaly width:height 120) allList)
    	allList=cons(list(symmetry finalx_f2:finaly_f2 width:height 120) allList)
        ; the fields all appear OK even if you don't reverse, but if
        ; you use tab to move through the fields, they are in the wrong order
        ; unless you reverse the list to be from top to bottom
        allList=reverse(allList)
        hiCreateAppForm(
            ?name 'ExampleForm
            ?fields
                append(
                    list(
                    allList
  • mantang
    Thank you for your examples. It is very useful to me.
    ManChak
  • mantang
    In the for loop, I created inst_sel button for each group (0-9) next to "group_instance" string field. I click "inst_sel" button and choose multiple instances in schematic. The callback function "CCSbtnFld1CB" copies selected instance names to the corresponding "group_instance" string field. However, I do not know the good way to pass correct group number (0-9)  to CCSbtnFld1CB and assign the return value of "CCSPointsDone" procedure to  "get(ExampleForm concat('instances num))->value". Any suggestion ?
          allList = nil
          startx = 0
          starty = 210
          width = 600
          height = 30
          for(i 0 9
               ?prompt sprintf(nil "Group%d instances" i+1)
               ?defValue ""
                                        ?value "Y"
               ;                         ?callback list(
               ;                                        sprintf(nil
               ;                                        "symmetryCB(hiGetCurrentForm() 'symmetry%d %d)"
                ;                                         i i
                j                                         )
       inst_sel = hiCreateButton(
              ?name concat('inst_sel i)
              ?buttonText "Select instances frrom the schemeatic"
    ; ?callback "CCSbtnFld1CB(hiGetCurrentForm())"       ;  Original code works
                 ?callback list(
                      sprintf(nil
                           "CCSbtnFld1CB(hiGetCurrentForm() %d)"   ; New code does not work
                            i
    xoffset = 20
    finalx = startx
    finalx_inst_sel = finalx + xoffset + width
    finalx_f2 = finalx
             flist = list(
                  list(inst_sel finalx_inst_sel:finaly 50:height 30)
                  list(symmetry finalx_f2:finaly_f2 width:height 250)
    hiCreateAppForm(
              ?name 'ExampleForm
              ?formTitle "Test"
              ?fields
                append(
                  list(
                    list(cellName 0:70 600:30 200)
                    list(viewName 0:100 600:30 200)
                    list(sep3 0:205 600:0)
                 allList
    ) ; let
    procedure(CCSbtnFld1CB(theForm num)
    let( ()
       ;    printf("number: %d\n" sum)
           enterPoints(
                ?prompts list("Click to select instances in the cellview. Press Esc key when done with selections")
                ?addPointProc "CCSAddPtCB"
              ?doneProc "CCSPointsDone"
           );enterPoints
        );let
    );procedure
    procedure( CCSPointsDone( w done pts)
         unless( done
                get(ExampleForm concat('instances 0))->value = buildString(
                setof(obj geGetSelSet()
               and(obj~>objType=="inst"
              obj~>purpose!="pin"))~>name)   ; Hardcode 0 to test the instance selection code
         );unless
        t
    );procedure
    procedure( CCSAddPtCB( w ptlist )
             geSelectPoint(w car(last(ptlist)))
    );procedure
    ManChak
