  3. How to set global clock signal routing in soc encounter...
  • Subscribers 94
  • Views 15017
How to set global clock signal routing in soc encounter?
Renee
Renee over 18 years ago
 Is there any way to route clock signal globally as did with Vdd! and GND! signals? Can I create a ring or stripe especially for clock signal and connect gates' clock signal to them?
Thanks in advance!
Renee
  • Kari
    Kari over 18 years ago
     Hi Renee,
    It kind of sounds like you want to do a clock mesh. I don't have any direct experience with clock meshes, but there is a section in the Encounter User Guide about this (appendix B for SOCE 7.1). Take a look and see if that meets your needs.
    - Kari
